[ROM] Probox 2 Air
    [ROM] Probox 2 Air
    Hello guys,
    today i bring you a rom for the Probox 2 Air. This rom is quite different the the stock rom because of that it's first install method it's only possible using the Amlogic USB Flash Tool.
    What's inside
    • Changed system partition size from 2GB to 1GB. This will give you one 1GB more in Data or Internal SDcard, i really don't seem why they did this.
    • Properly rooted with SuperSU, no strange binaries involved. The root method is a slightly modified systemless root, i placed SuperSU.apk and su.img inside the system. I did this so that on a factory reset you won't lose root
    • init.d support
    • Updated Gapps inside
    • I didn't touch the launchers, they aren't all bad. Might mod them in a future release
    • included some apps as user. Passthrough Fix app that i kanged from prahjister. Also kanged librmtp.so from superceleron for the kodi inside
    • Used only one device tree file.
    • Multi Window. Enable it in developer options, Drawing tab.
    • Fix Enter key on keyboards
    Install Method
    • Download the zip and extract it
    • Open the USB Flash tool, and select the image and press START. Connect a USB male to male only to your PC
    • Power Off your PB2Air, remove power cord also.
    • Press and hold the reset pin in the bottom and plug the USB cable.
    • The tool will show a connect successful message and start the flashing.
    Download
ID:	599187 Click image for larger version
ID:	599188 Click image for larger version
ID:	599190 Click image for larger version
ID:	599191 Click image for larger version
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    Reserved for future use
      zip is not good ;(
        You can't unzip it ?
        Tapatalked
          Its unzips ok here
            i have 2 errors,crc failed,parse burning image fail. (2.0.5.15 usb b tools )
              Update your burning tool. At least to 2.0.6.2
                i get 2.0.6.2 build 2 but agan i have prob with parse image fail...nvm i will try to download 1 more time
                  Hi, I used 2.0.7.2 Build2 and I had no errors.
                  Cheers
                  Kevin
                    i have bad download 5 times
                      Same here no errors 2.0.7.2.
                      Cheers
                        Seems my USB cable was screwy but then again it was an old spliced job from years ago. Turns out it just needed a bit of solder and I flashed just fine now. I like the Freaktab boot logo. Thanks.
                          Good that you have it sorted out.
                          Tapatalked
                            This rom also works on the Beelink MiniMX III II. Just in case
                              everything working on the x9 except (wifi/bluetooth/network) runs very smooth too. nice work.
