Meegopad T08 Mini PC TV Stick 32bit Windows
    Click image for larger version  Name:	1474272157886635.jpg Views:	1 Size:	92.1 KB ID:	599824
    Intel Cherry Trail x5-Z8300 Quad Core CPU
    Intel HD Graphics:
    32bit Windows 10
    4GB DDR3L RAM + 32GB eMMC ROM, 128GB maximum extended capacity:
    2.4GHz / 5GHz WiFi
    Remote control: batteries not included
    Click image for larger version  Name:	20160919095016_80871.jpg Views:	1 Size:	181.0 KB ID:	599825
    Specification
    Brand: Meegopad
    Model: T08
    Type: TV Box
    GPU: Intel HD Graphic
    System: Windows 10
    CPU: Intel Cherry Trail Z8350
    Core: 1.84GHz
    RAM: 4G
    RAM Type: DDR3L
    ROM: 32G
    Max. Extended Capacity: 128G
    Maximum External Hard Drives Capacity: 500GB
    Color: Black
    Decoder Format: H.264,RealVideo8/9/10,RM/RMVB
    Video format: 1080P,RM,RMVB
    Audio format: AAC,ACC,AFE,RM,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: No
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: 3.5mm Audio,HDMI,Micro SD Card Slot,Micro USB,USB 3.1 Type-C,USB2.0
    Language: Multi-language
    DVD Support: Yes
    HDMI Version: 2.0
    Other Functions: Others
    External Subtitle Supported: No
    System Bit: 32Bit
    KODI Pre-installed: No
    Power Type: External Power Adapter Mode
    Power Adapter Input: 100-240V / 50-60Hz
    Power Adapter Output: 5V 3A
    Product weight: 0.200 kg
    Package weight: 0.300 kg
    Product size (L x W x H): 14.20 x 4.20 x 0.99 cm / 5.59 x 1.65 x 0.39 inches
    Package size (L x W x H): 16.00 x 8.50 x 5.00 cm / 6.3 x 3.35 x 1.97 inches
    Package Contents: 1 x Meegopad T08 Mini PC TV Stick, 1 x Power Adapter, 1 x English Manual
    Click image for larger version  Name:	20160919095016_73607.jpg Views:	1 Size:	148.0 KB ID:	599826
    Gearbest
    Looks like this has now finally arrived to market.
    http://www.gearbest.com/tv-box-mini-pc/pp_456970.html
    http://www.geekbuying.com/item/MEEGOPAD-T08-Windows-10-Intel-Z8350-4G-32G-Ultra-MINI-PC-375313.html
