MX2 “Authorization Problem”
    I flashed my MX2 to 1.7a and it started fine. The first thing I wanted to do was get myWi-Fi setup and working. Tried several times what seemed to be simple on the stock MX2.
    When trying to connect it always comes up with “AuthorizationProblem”. I’ve checked and re-entered the password, reset/rebooted, clock & time, changed router security method from WPA-Personal to WPA2, rebooted router, etc.
    Did I skip a step in the 1.7a instructions? (All wentsmoothly to completion.)
    I can’t come up with any more options. Can you?
    My configuration is: Windows 7, WRT54GS router with WPA2, IMITO MX2 with finless 1.7a.
    I’ve searched the forums here and Googled but didn’t come upwith anything else.
    Thanks in advance,
    Tazer98
    MX2 “Authorization Problem” - SOLVED!
    It’s finally solved!!
    I did it by trial and error method. In addition to what I tried in my first post, I set the wireless channel back to 6 (was working prior to flashing), changed WPA Algorithms to AES instead of ‘TKIP&AES’, changed the WPA Shared Key,rebooted both the router and Imito. Now it works as before, though a bit faster and cleaner with 1.7a!
    Tazer98
