Very unique S905+S2+T2+C+Home Alarm
    I have received one special S905 device which is under development,there is no sale.
    Maybe later,when sw will be 100% perfect.
    It have triple tuner,Ca slot and smart home alarm system.
    Separate Smart options are:
    -Door sensor.
    -Wi- fi Cam.
    -Smoke sensor.
    --Water leakage sensor.
    -Power switch.
    -Infrared motion sensors.
    All sensors are wireless and all operations are on mobile phone app,like arm ,disarm or watching wi-fi cam outside of home.
    Every sensor have internal battery.
    Inside the box there is battery if there is no power and there is slot for internal sata 2,5 hdd for pvr.
    For now i am on satellite, and i think more then 90 pay channels works fine via special cam file.
    There is PIP function,you can have on one main desktop: the main picture from satellite ,one from android ,and one from wi-Fi cam.
    All settings are very ,very simple,all alarm operations are via phone.
    Free 100Gb space for your files:
    https://degoo.com/g/Ov7nAz0
