The T051 octacore firmware is based on my firmware made specifically for the Z4. The geekbox firmware is only a mod of an existing geekbox firmware, so the differences are quite large, literally every image (sys/boot/misc/resource etc) are different
T051 - October Update: First RK3368 True OctaCore Release
Originally posted by l30ns View PostI'll be watching this thread hoping your next iteration ROM works for me same as the 1st one.
Originally posted by notShomari View Post...try this firmware.
Sad to say that Wifi doesn't work at all.
I tested other things:
Optimisations seam to work flawlessly. I'm not sure if RK hardware acceleration work in Kodi, but thats something I can work with. Also the DPI adjustment and bottom ribbon buttons (home / app switcher / lack of power button / lack of settings button in top notifications drawer is something I can fix on my own)
P.S. I opened the device just to clear conflicting data on the WIFI/BT chip and it is AP6330 i68 is using
Thanks, man!
su
dmesg | grep wifi
... also, I'll upload an update soon with wifi fixes and possibly others.
Thanks, man!
Originally posted by l30ns View Post2.4G WIFI works, but 5G does not. I hope this doesnt take too much of your time ;-/
Originally posted by l30ns View PostWhile it downloads: Is this Kernel / Resources tweak you are doing or does it link with ROM itself?
I mean - Can I flash your Kernel / Resources on top of other 5.0.1 ROM's once we get it going?
Do I get it right?
P.S. I'm flashing the update in a moment.
edit: you can definitely take the separate images and combine them with other roms. I don't think the results would be satisfactory, but you never know.
Originally posted by notShomari View PostADDED 5G WIFI
Do you need any other tests / logs of anything out of it?
P.S. Did you intentionally kill the bottom status-bar Home and AppSwitcher buttons? I have them on remote so no problem for me - just curious.
P.P.S. I'll stick to your kernel / rom etc.. image combination. Just wanted to know if this wifi fix & kernel tweak set is transferable to other roms or not. Now I know
Thanks for the effort!
There are currently 6592 users online. 1 members and 6591 guests.
