Transfer Data from iPad to Android Tablet
    Bought a new Android tablet and plan to sell my old iPad on ****. However, I don't know how move the data from iPad to the new tablet. I tried manual transfer a few contacts but it is too time consuming. Is there any fast and conformable way for data transfer? thanks
    Can't you install a Gmail account on and Ipad?
    If so Gmail will auto synchronize your contacts data with the account on your Android device, or you could upload it to Google drive or any cloud server for that matter, then download it to your Android dvice
      Originally posted by qbranzen View Post
      Bought a new Android tablet and plan to sell my old iPad. However, I don't know how move the data from iPad to the new tablet. I tried manual transfer a few contacts but it is too time consuming. Is there any fast and conformable way for data transfer? thanks
      I'm not familair with android. Do you sync your device to a computer? If so then once you get those files onto a computer you can use that computer to get them onto your iPad.
      Another way would be to use a service like dropbox, where you upload the files, then download them onto your iPad (with the dropbox app)
        How about the other data? I followed your suggestion and got my contacts transferred via Gmail. thanks
          With Phone Transfer tool, you can easily transfer data from iPad to Android tablet. It can directly transfer data like contacts, messages, photos, apps and more on PC between mobile phones.
            1. Mount your iPad on the computer as an external hard drive by plugging in a USB cable. Open it and find the DCIM folder. All photos you take and download are there.
            2. Connect your Android phone or tablet to the computer with the USB cable. Likewise, navigate to its hard drive.
            3. Open the Android hard drive and find or create a photo folder.
            4. Copy the photos from iPad DCIM folder to your Android photo folder.
              To transfer data between ios and android devices, you can only use professional data transfer tool, cuz it is not possible to transfer data between different operation systems. Some professional phone data transfer programs allow you to share data between android phones, or android and iphone without limitations of different operation systems.
                If you failed to transfer data with above solutions, you can search phone transfer tool on google, and try some popular ones for free. Such tools are able to transfer between mobile phones simple and easy. Support various types of iPhone, Nokia and Blackberry. From iOS to Android
