m96x tv box 2gb 8gb S905X AMLOGIC chip android 6.0
Visa versa it works also the m96x fw will work on the x96 box.... only diffrence i saw was the lateste firmware update from the m96x is from december 2016 and the latest x96 firmware dates from november 2016 so the m96x has newer firmware. But i never found a stock img of the m96x firmware. Either way its a pretty good box goodluck
Originally posted by brickmojoccatz View PostVisa versa it works also the m96x fw will work on the x96 box.... only diffrence i saw was the lateste firmware update from the m96x is from december 2016 and the latest x96 firmware dates from november 2016 so the m96x has newer firmware. But i never found a stock img of the m96x firmware. Either way its a pretty good box goodluck
zip file cant be flashed by usb burning tool
You should flash the above TWRP first than u can flash those zip files.
This link has the original fw in zip format
http://chinagadgetsreviews.com/downl...96-tv-box.html
You can use Abduls TWRP find it here http://freaktab.com/forum/tv-player-...-0-probox2-air
But u need a way to flash it first, is your device accesable through adb ?
Originally posted by brickmojoccatz View PostYou should flash the above TWRP first than u can flash those zip files.
The button does nothing indeed, sorry to confirm. I did find this post on the libreelec forum. " The M96X doesn't have a recovery button, that's why I had to use the rs232 interface" Those rs232 cables come kinda cheap. Anyway the link to the thread is https://forum.libreelec.tv/thread-2347-post-22123.html maybe you could contact the guy to see how he did it. Goodluck hope u get ur box up and running again.
There are currently 1351 users online. 1 members and 1350 guests.
