regarding cable TV Vod/live streaming apps, I know CNN , sky and others use them, I use yesGO personally.
The app open and allows to login and pick your content but crashes once you hit play.
Anyone has this also ? Removing the word "test" from build.prop is the way to fix ?
Please share your dealings if you had or have any....
Cheers
Stock s905x Nexbox a95x 2/16
