I ordered a MK808b Plus form geekbuying some time ago. It worked great out of the box but video playback wasn't exactly smooth. I tried some several different ROMs and found one I liked from Droid-TV. I used it for some time, focusing mostly on peripherals and getting around the one usable USB port. When I finally setup up the configuration like I wanted, with the USB hub and all, I went to do something about the ouput resolution and bam, black screen. Restart - > no signal. Well damn.
Now I tried a lot of things. The USB burning tool, no luck. Windows doesn't even recognize the stick. Nothing in the device manager. No beeps, no sounds. The stick powers up, the blue light is there.
Next with the SD card update. I took one out from my phone, formatted it as per these instructions. No luck. Black screen. (btw for how long should I be holding the reset button after powering on the device? 10 seconds? a minute?)
Any ideas?
