My screen has a hazy color-noise layer over it. This is more visible in whiter areas. It really ruins the crisp look of the display. Its not too bad in videos, but annoying on wallpaper and web pages.
I know the actual LCD is not making this noise, i can physically see the noise is above the LCD when looking from an angle. Also, the noise is on the bezel, not just the display.
Also, this layer is extremely prone to fine scratches. I made some scratces when wiping with the sleeve of my hoody.
Also, there are three small bubbles under this layer on the bezel.
Therefore I think the noise is coming from the plastic layer that seems to be glued to the display (or the glue adhering the layer).
I don't know what this plastic layer is for. I don't think it is the touch digitizer as it has no wire ribbon to it and they usually have a frame. Physically, it looks exactly the same as a screen protector.
I cant get my nail under it to try and remove it (I won't try too hard as I don't know if it is necessary).
I don't have a camera good enough to capture the noise. Here is an image of the plastic layer's edge:
I am asking other U30GT2 owners. Do you have a plastic layer like this? And or do you have the faint color noise when you look at a white web page. (The noise is on the bezel too remember).
