Driver problems pipo m8 pro 3g
Originally posted by bokkie View PostSupport your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
Re: Driver problems pipo m8 pro 3g
No, a menu comes up. You navigate with scrolling up/down by swiping (its slow), and select option by power button. What you're looking for is within menu alternative "Mounts anf Storage" on the main menu.Support your local flasher
Originally posted by bokkie View PostThanks for the tip Mate, that did the trick.
Although I did notice that when I plugged it in when it was in recovery it said cannot find drivers for your rk3066 device. Isn't the pipo m8 pro a rk3188 device?
Reboot to flash mode with the Reboot app, while connected by usb. Go to device manager - and if the tablet comes up as anything, try updating with these drivers: https://dl.dropboxusercontent.com/u/...ockUSBv3_5.zip
Note: After 2 minutes of no flashing activity, the tablet will power off. Just boot it normally, or hold esc+power to boot (USB CONNECTED) from powered off state, and keep holding for a few seconds. It should boot straight to flash mode. (loader).Support your local flasher
I have never encountered this on my Windows 7 Started laptop, but on my Windows 7 64 desktop I have been seeing Windows trying to load drivers every time I connect a tablet, which I stop Windows from searching further for it. If I manually put the tablet in flash mode, either by external keys or by using the Reboot app, the Flash Tool recognizes the tablet in flash mode and I'm able to flash with no problem...I'm just unable to use the button on the tool to reboot to flash mode.
It isn't really a problem, since I know it is happening...but I thought I would share this experience.Randy
Originally posted by bokkie View PostIt's in vista that the message comes up.
I'll give it a go tomorrow, is the reboot to flash just so that the pc sees the tablet?
Are those drivers updated from Rileyrom 1.7 which I flashed?
These 2 different modes will represent Windows with 2 different Hardware ID's from the tablet, but only one of them will show in each respective mode.
A multifunction printer might have for instance printer, scanner, fax and sd card reader functionality. Each of these "functions" will have its own hardware ID for the respective drivers (for each function) to adress. And, the multifunction printer will show ALL of these hardware ID's simultaneously. This defines it as what Windows calls a "Composite Device". It has several functions, each with its own Hardware ID and each Hardware ID has its own driver - yet Windows recognizes it as a single unit.
Now the RK3066 and RK3188 tablets (for instance your M8pro) - Only show one Hardware ID at a time - one for Flash Mode (loader), and one for USB storage. Each mode has its own driver; Flash mode uses the RockChip drivers, USB storage uses Windows own native USB drivers.
When it is designed this way (only showing one Hardware ID at a time in different modes) - Windows will "see" your tablet as 2 separate individual devices.
The drivers with the RileyROM 1.7 (i don't know about the 3G version, just downloaded wifi-only version) - are 3.0. The drivers I linked to are 3.5. Always use the latest drivers available if you can - so please try to upgrade them as instructed earlier.
After that, I suggest that you connect with the tablet on in "normal" (usb storage) mode, no usb debugging - and leve the flash tools closed. Go to device manager, look for device (that should now be in USB mass storage mode) - and "update" driver. Let windows search for the drivers - and install standard windows USB drivers for it. Those are the correct drivers for USB mass storage mode.Last edited by pr0xZen; 16 July 2013, 11:27.Support your local flasher
An easy solution for those stubborn android driver problems
For those stubborn cases with Vista or Windows 7, there is an easy way to remove (or force-remove) wrong drivers that remain stuck in the Windows driver store. (The driver store was introduced with Vista and kept with later versions to enable Windows to store trusted drivers for reuse. It causes a lot of trouble)
The following application saved me from this madness once:
DriverStore Explorer (http://driverstoreexplorer.codeplex.com/) is more than an explorer. It allows deletion of driver packages from the store, even enables force deletion for some drivers that resist being removed the standard way.
In my case under Windows 7, even though the correct drivers appeared to install correctly, they would let me flash the tablet, but not use ADB. It failed to see the tablet, so I could not root the tablet or do other basic jobs. I even built a special ADB driver for the M8 pro... Nothing worked, I was going crazy!
That's when I tried DriverStore Explorer. It showed me several (5 if I remember well) old drivers that I had thought had been successfully removed a long time ago. Even some that I had used for my 3 years old tablet. They were still lurking in the store.
I deleted all these old android drivers, had to force delete 2 or 3 of them if I remember well.
After that I reinstalled the latest driver and everything (flashing and ADB, etc..) is now working as it should.Last edited by pan2fire; 31 July 2013, 00:19.
I would advice care when using this solution. If the "errorous" driver is one of the Windows native usb drivers - keep in mind that these are an integral part of Windows usb function - and actually deleting these (if this program can actually do so) may cause a wide array of issues.Support your local flasher
Originally posted by pr0xZen View PostI would advice care when using this solution. If the "errorous" driver is one of the Windows native usb drivers - keep in mind that these are an integral part of Windows usb function - and actually deleting these (if this program can actually do so) may cause a wide array of issues.
I have never tried it however as all the Android drivers lurking in the driver store of my PC had been installed by me.
My guess is that removing an automatically installed bad Android driver to replace it by a correct driver from the manufacturer would be no different from removing a previous manually installed Android driver to replace it by a correct manufacturer driver.
However it is only a guess and pr0xZen is right to give this warning.
try this on my pipo m9
Hi..
2 years after, Win 8.1, same problem - on Pipo m9pro.
I read all this thread, try all the solutions, step by step, nothing helps.
RileyRom driver can't be installed. Windows always install the other driver, and i can't install the RileyRom on my tab.
Maybe today, 2015, new solutions?
Thanks.
There is a new RK-Release_DriverAssitant tool with support for xp/win7/win8!
It's for the RK3288 but maybe it will also work for the older RK3188 processor (installed in the PIPO M8 & M9 tabs).
In the threads the user are telling that even the installed old RK3188 drivers are working with the RK3288 devices. So maybe it could work the other way (new driver with old processor).
1.Release_DriverAssitant
Install drivers for tools,it's easy to install and uninstall.
Install ADB drivers too.
It's better to uninstall the previous drivers first,then install the new one.
Here is the original thread.
good luck
There are currently 2810 users online. 3 members and 2807 guests.
