HPH NT-N8 RK3229
    HPH NT-N8 RK3229
    HPH NT-N8(Plus) RK3229 specifications:
    · CPU: RK3229 Quad Core ARM Cortex A7 @ 1.5 GHz
    · GPU: ARM Mali-400MP2
    · RAM: 1/2(Plus) GB DDR3-1866/LPDDR3-1333
    · Storage: 8/16(Plus) GB EMMC
    · Ethernet: 100 Mbps
    · Wifi: 802.11 b/g/n, 2.4G /5G Dual-Band(Plus)
    · Bluetooth: Support BT 4.0
    · HDMI Output: 2.0
    · AV Output: (3.5mm port for tv out or stereo speakers)
    · Audio Output: S/PDIF (2CH, 5.1CH), HDMI Audio via HDMI Out Port
    Supports DTS/AC3 Pass-through, TrueHD, DTSHD, EAC3
    · Memory Card: TF card reader Micro-SD card interface
    (Supports 1GB/2GB/4GB/8GB/16GB/32GB cards)
    Video Codec – 4K2K 10-bit H.265 @ 60 fps (Up to 200 Mbps),  4K 10-bit H.264 @ 30 fps (Up to 250 Mbps) and 4K 8-bit VP9 @ 30 fps (Up to 200 Mbps)
    · Decoder Formats: 10-bit H.264, 10-bit H.265, VP9, AVC, HD AVC/VC-1, HD MPEG1/2/4
    Video Formats: 1080P, 4K x 2K, ASF, AVI, DAT, FLV, M2TS, MKV, MOV, MP4, MPEG, MPG, RM, RMVB, TP, TRP, TS, VOB, WMV, 3D MVC
    Audio Formats: FLAC, MP3, OGG, WAV, WMA
    Picture Formats: BMP, GIF, JPEG, PNG
    · Video Encoder – 1080p H.264 and VP8
    · 4 x USB 2.0 Ports
    · Operating System: Android 5.1
    · Language: Multi Language support
    · Other features: Support DLNA, Miracast, Android/IOS Remote Control App
    · 1080p Youtube Playback Support, Universal Storage
    Package Contents: 1 x TV Box, 1 x EU/US/UK/AU Plug 5V, 3A Power Adapter(correct one will be shipped according to your country), 1 x HDMI Cable, 1x USB to USB Male Cable(for connecting to PC)
    1 x IR Remote Control, 1 x English User Manual
    There are 2 models
    Specs
    NT N8 - 1GB DDR+8GB EMMC+AP6210 Wifi (2.4G + BT4.0)
    NT N8 Plus - 2GB DDR+16GB EMMC+AP6255 Wifi
    (Dual-band wifi 802ac + BT4.0)
    Last edited by JDfense; 11 November 2016, 15:10. Reason: no selling links in the support area
    One of the more interesting cases, for sure.
    Looking forward to your impression of it.
      Picture of PCB.
      There is also a heatsink on the PCB, it is just not shown in that photo.
      I haven't seen PCB pictures of other RK3229 devices yet, so quite interesting.
      New Picture of the bottom of the casing
      There are also 4 rubber pads in the corners not shown in this picture.
        A review added.
          Custom firmware will be uploaded today.
            New v1.2 HPH NT-N8 firmware
            http://www.multcloud.com/share/93ad6...6-73f85d53d5aa
            Pass: nagrace
            Added auto frame-rate switching
            Timeout for live streams
            Fix some other Kodi bugs in NTMC
            If you are using a 4K tv, please turn deep color/hi color mode on first on your tv if you get no signal.
              Pass: nagrace
              Does NTMC includes this patch?
                Originally posted by Ben.Efrati View Post
                Yes, so I hope it works now.
                  anyone else having probs downloading ?
                    Yes first download corrupt, second one ok...use a single download I found worked....
                    Nice Moe lot snappier, looking OK
                    Black screen a second before video plays in NTMC set up frame rate I guess.
                    Some that don't play screen goes gray get audio only or part thereof.
                    Fifa world cup ok failed to play last time
                    More testing...
                      I'll post the mega link later.
                      When I'm not at my PC, I usually can only get multicloud links.
                        Netflix same 24 or sink problem, you knew that :-)
                        NTMC not a slow as previous looks ok
                          could you upload the apk, please?
                            Does this F/W work on the NT-N8 Plus version too?
                              Yes it works fine, I have the plus version
