Iam not sure if its 1.6, the suggested method or the fact that i changed my homerouter (finally) to my old netgear n300 with tomato rom - but the tablet seems quite alot snappier in browsing and most other things too. the "wait several seconds for keyboard" hasnt struck yet at least
Pipo M8 Pro 4.2.2 RileyROM 1.6 with SDK 2.0
The most important thing is that it (hopefully) remedied your problem Your network shouldn't affect the overall performance - although it can affect Chrome keyboard performance if the connection is /REALLY/ bad - and you use suggestive search (google hits come up /as/ you type - changing "with every letter".Support your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
Originally posted by pr0xZen View PostThe most important thing is that it (hopefully) remedied your problem Your network shouldn't affect the overall performance - although it can affect Chrome keyboard performance if the connection is /REALLY/ bad - and you use suggestive search (google hits come up /as/ you type - changing "with every letter".
Another thing - i noticed in the rom some apps (SU rights manager) are in chinese, took a while before i figured out which of the buttons were allow access for root rights
Yes, that was my bad.
I noticed this firmware was already rooted, so I left their rooting stuff alone (I was curious to see what it was) My next ROM will go back to the same Superuser app.
I'm just seeing this ROM on my tablet for the first time today, because I had a hardware failure with my tablet. Now I have a new one, but it isn't quite right, either.Randy
For the record, my 'eraseIDB' part only every counts up to 4096 as well. I thought this was an issue at first but turns out that the issues were caused by a) incorrectly using a USB 3.0 port which doesn't work and b) flashing on my work PC plain doesn't work. Not sure why but not worried because it works fine on my home PC - using USB 2.0 of course! Even on my home PC mine still only counts to 4096 but the ROM works fine. I don't know why this is.
@pr0xZen I installed the stock ROM using the RK batch tool which I downloaded from the Pipo website. The problem I had is that the instructions on the Pipo website to get the tablet into flash mode are a total load of nonsense. They don't work at all. Instead, I simply used the 900SuperSupport ROM flash tool used by RileyRoms and clicked 'Reboot2Flash'. I am then able to flash stock ROM using RK Batch Tool 1.7 with no problems.
I have flashed so many ROMs lately, I really can't remember the actual count for the M8 Pro.
The bottom line is that the ROM works for you. That's great!!!!!
RandyRandy
Originally posted by vipergrm View Post@pr0xZen I installed the stock ROM using the RK batch tool which I downloaded from the Pipo website. The problem I had is that the instructions on the Pipo website to get the tablet into flash mode are a total load of nonsense. They don't work at all. Instead, I simply used the 900SuperSupport ROM flash tool used by RileyRoms and clicked 'Reboot2Flash'. I am then able to flash stock ROM using RK Batch Tool 1.7 with no problems.Support your local flasher
There are currently 1799 users online. 6 members and 1793 guests.
