Which nand pins to short on a MXIII-C_V1.2_20160419 board ??
    Hello, I just purchased .... what i though was a MXiii G 2gb/ 16gb box. The box some reason Bricked, Only the red light comes on. When i opened it up it had a sticker with the following info MXIII-C_V1.2_20160419 board.
    I tried the USB method but continues to fail at 2percent. Can any one tell me which nand pins to short to force the USB firmware ????
    Hi Mr.Noodle, Could you let us know what numbers are on the nand or post a clear photo of it.
    Cheers
    Kevin
      This Nand is a.....
      FORESEE
      NCEMBSF9-16G
      01L1604079143
      1618
        Hi this should do the job for you.
Name:	Foresee NCEMBSF9-16G Reset Pins.jpg
        Cheers
        Kevin
          Excellent !! Thanks alot Kevin. I'll give it a shot and let you know.
          I tried shorting out the pins and it still failed at 2 percent.
          now im stumped. Any suggestions ????
          Im using burning tool V 2.0.5.15 build 9
            Hi try USB_Burning_Tool_v2.0.7.2_build2 :- https://www.dropbox.com/s/1333vr2s0v...uild2.zip?dl=0 .
            Are you flashing with the factory firmware or 3rd party one.
            Cheers
            kevin
              Hi all
              it is important to change under View the "temperature range" ,i changed it from 20 to 60,and did or have you press the Resetbutton behind the AVJack till you conntected it to PC ???
              i think you have to use the 2 small golden points beside the pins i had the same on another PCB.
              good Luck
              gefattern
                Thanks for your reply Kevin ! I'll give V2.0.7.2 a try tomorrow. As far as the Flash, I do believe its a factory firmware. I'll throw you an update on my progress tomorrow.
                and thanks gefattern for your reply as well. I did press the button behind the A/V Jack till it connected to the PC.
                Do you mean SHORT out the 2 golden pins as well as ...Ill call them 5 and 6 down from the left hand side of the Nand ???????
                I only shorted The 5 and 6 pin.
                  Hi once more
                  i mean on Kevins Picture / right Side / the 2 round golden contacts / if yours have them / try / what about Pin 7/8 they work on RK Devices.
                  What did the Flashtool says on 2% whats wrong ???
                  good Luck
                  gefattern
                    Hi
                    I also seems to have the same problem however I have contraditory information on the box.
                    In the sticker in the board is says MXIII-C V1.1 S812/2G/16G/AP6330 (PCB 1.5mm) but in the other side of the board and printed on the board it says MXIII-C_V1.2_20160419.
                    Nonetheless I have been unable to to put the box to work. I have posted before some information in this page.
                    http://freaktab.com/forum/tv-player-...t-mxiii/page36
                    Nand = Foresee NCEMBSF9-16GB
                    01L1605118552
                    1620
                    Questions:
                    1) I should use this firmware or other?
                    Firmware that I try:
                    MXIII-C_202L1 for USB Burning Tool
                    MXIII-C_202L1 SD for sd card
                    The above firmware i get it from here:
                    https://translate.google.com/transla...9136&sandbox=1
                    2) Can you explain in more detail the procedure that I should do
                    What do you mean by short the 2 round golden contacts (these dont seems to exist in my nand) ? Link them together? And then what? turn on the device?
                      Hi redcab
                      first of all the Sticker shows the Specs of the Device.The Boardnumber shows Typ and Date of Production,normal.
                      If your Box is not bricked use the Flashtool for Firmware,not needed to shorten the pins.
                      Have you flashed the linked FW's ??? or you want it and don't know how ???
                      If you must know how look for S812 Flashing Tutorials in S812 Section,Google and YouTube.
                      now i must sleep i am tired / ask if thinks unclear / always Backup your Data.
                      nice Day
                      gefattern
                        redcat try the firmware you posted
                        the eMMC is a 16GB package as netxeon currently uses these eMMC's if you box is detected by usb burn tool then no need to short pins
                        if you are getting 2% then incorrect firmware a log from usb burn tool would help also
                        sometimes you can force it by selecting force all erase then reflashing again normal flash from the drop down selection of usb burn tool.
                        Bugs are Sons of Glitches!
                        JustMe
                          Thak you for the answers.
                          I suppose that the box is bricked. Using the usb burning tool I get connected sucessfull but I always get this error (bellow), and nothing happen.
                          If I use the SD method nothing happen. No image at all always black.
                          Error that I get with USB tool
                          [0x10205004]Romcode/Lead UBOOT/Check decompress/Error result
                            Hi redcat,
                            have you tested the hints of "JustMe" or another Version ???
                            Maybe the Fw is incorrect.Upload the logfile of this flash for JustMe.
                            do not give up so fast
                            gefattern
                              Can anyone help me please to unbrik the MIII-G. Attached is the log file from the USB burning tool. I can get a connection with the burning tool but always get the following error at 3%.
                              I also try the force erase all but dont worked.
