Egreat A5 Hi3798CV200 4K HDR 2G/8GB 2.4ghz WIFI Gig LAN Dolby DTS-HD 3.5" SATA HDD BT.
Egreat A5 Hi3798CV200 4K HDR 2G/8G, 2.4ghz WIFI 1000M LAN Dolby DTS-HD 3.5" SATA HDD Bluetooth Media Player
A few bucks (40) off with this Coupon EGTA5TV
GestbestModel A5 Case Material Aluminium alloy Color Black Hardware CPU Hi3798CV200 Quad core ARM Cortex-A53 up to 2.0GHz, ARMv8-A architecture with multimedia accelerator engine Neon, build in hardware JAVA accelerator and hardware floating point coprocessor GPU Build in ARM Mali-720 3D GPU, OpenGL ES 3.1/3.0/2.0/1.1/1.0 and OpenVG 1.1 support, OpenCL 1.2/1.1 full profile/RenderScript support, Microsoft DirectX 11 FL9_3 support, ASTC(Adaptive Scalable Texture Compression) support, Pixel fill rate is greater than 2.7Gpix/s, Triangle up to 280Mtri/s, Floating point operations up to 103GFLOPS Memory 2GB DDR3 Flash 8GB Flash LAN Network 10/100/1000M RJ45 adaptive ethernet WiFi Network 802.11 b/g/n 2.4G Wi-Fi Bluetooth BT4.0 Interface 1 x SATA 1 x USB 3.0 host 2 x USB 2.0 host 1 x TF card 1 x RJ-45 Ethernet Jack (10/100/1000Mbps) 1 x HDMI2.0a(up to 4K2K 60fps output) 1 x Optical SPDIF, 1 x Coaxial 1 x AV 1 x DC in Jack 1 x LED White-Light dot matrix panel, 1 x Power LED indicator System OS Google Android 5.1.1 File System FAT16, FAT32, NTFS Video Decoder HiVXE2.0 video decode engine
H.265/HEVC Main/Main10 [email protected] Hight-tier, 4Kx2K@60fps and 1x1080p@30fps parallel decoding
H.264 AVC BP/MP/[email protected], H.264/AVC MVC up to 1080p@30fps
VP9 up to 4Kx2K@60fps
VP6/8 up to 1080p@60fps
MPEG1 up to 1080p@60fps
MPEG-2 SP@ML,MP@HL, up to 1080p@60fps
MPEG-4 SP@L0-3,ASP@0-5, support GMC, support Short-Header format, up to 1080p@60fps
AVS JiZhun [email protected], AVS-P16(AVS+), up to 1080p@60fps
VC-1 SP@ML, MP@HL, AP@L0-3, up to 1080p@60fpsVideo Formats MKV, ISO, MP4, AVI, MOV, MPG, MPEG, WMV, DAT etc. Graphics and Display Processing HDR support Audio Decoder MPEG L1/L2
Dolby Digital/Dolby Digital Plus Decoder-Converter
Dolby True HD
DTS HD/DTS M6
Dolby Digital/DTS pass throught
AAC-LC, HE AAC V1/V2
APE/FLAC/OGG/AMR-NB/WB
G.711(u/a)
Dolby MS12 decode & sound effect
HE-AAC transcoding DD(AC3) supportAudio Formats APE, FLAC, WAV, AAC, WMA, MP3, AMR, MID, OGG etc. Picture Decoder Full HD JPEG hardware decoding up to 64 million pixels
PNG hardware decoding up to 64 million pixelsPicture Formats JPG, JPEG, PNG, BMP etc. Language English, Simplified Chinese etc (will add new languages according to user needs) DLNA Protocol Support DLNA Protocol File share Samba, NFS WiFi hotspot Support Mouse/Keyboard Support mouse and keyboard USB
Support 2.4GHz wireless mouse and keyboard via 2.4GHz receiverGreat Player Blu-ray ISO Playback Support Blu-ray Menu Navigation Support HD Audio Passthrough Support 1080P Hardware Acceleration Support 3D Blu-ray ISO Playback Support DVD Menu Navigation Support Access Home Sharing Server Support Add-ons Support OTA Update Support Support Applications Online Browse all video websites ,support Netflix ,Hulu , Youtube etc APPs Apps download freely from android market etc Media Local Media playback,support HDD, U disk ,TF card Talk online Support Skype video call , Facebook , Twitter , QQ etc Tools Support DLNA, AirPlay, Google TV Remote etc Accessories What's in the packing box 1 x A5 UHD Media Player 1 x IR remote control 1 x DC 12V 2A power adapter with plug converter(1 x Europe plug converter, 1 x USA plug converter) 1 x SATA cable 1 x HDMI cable 1 x AV cable 1 x Optical fiber cable 2 x AAA battery 1 x User Manual Other Product Weight 516g Product Dimension 189 x 129 x 31.5 mm Packing Box Dimension 232 x 216 x 81 mm Last edited by trebor; 29 March 2017, 03:41.
Egreat A5 Hi3798CV200 4K HDR 2/8GB 2.4ghz WIFI, 1000M LAN, Dolby DTS-HD 3.5" SATA HDD BT Media Player
My first look at the Egreat A5,
Very well packaged and presented with all the bits to make it happen, and yes AU Power Adapter amongst thingsexcellent.
What's in the Box
Lets have a bit of a look on the inside, well made good construction, solid and well finished.
Under side of PCB, not a lot, WiFi chip and connection, and a power supply to a Thing.
Top Side of PCB, all the action happens here looks good
A Thing that shine light thru the top
Front Display, Looks Groovey
Back View Ports, SPDIF/Coaxial, Composite Video, HDMI, RJ45, Power
Side Ports, TF Card, USB3 and a USB2
Other side Sata Port and another USB2
Ram & eMMC
PHYceivers › 10/100/1000M for Gigabit Ethernet.
WiFi Chip 802.11b/g/n
Lights action and Camera. Great looking display and the thing that shines through the top looks good, and I was worried about Multi coloured thing.
Looks Excellent, One good look bit of kit.GearBest
More to come.Last edited by trebor; 29 March 2017, 03:37.
Yes Interesting Unit... Android but not as we are use to, own thing really.
Has VidOn installed (Kodi 16.1 worked) 16.1.2, build 4th November
This is a Media Player that plays media it sole purpose (it can do other things) no Google play as yet, but still looking, excellent player display on the front is Brill.
Plugged in a sata drive full of 4k demos, 400 mbit easy as with its inbuilt player, Different UI snaps soon. but looking good so far and it does physically look good.
I always said that this SOC was likely to be the best of the bunch when it came to the primary purpose of video playback and with the audio passthrough options, it certainly puts itself in the right spotlight from those perspectives.
Bit of a fiddle this evening, getting use to how it all works and what the deal is and the deal is looking pretty good indeed,
The A5 will play just about everything I throw at it easy either by Vidon or its own player and numerous other ways I am yet to find/appreciate,
Firmware update this day, to version 1.2.6 desktop and Firmware 1.0.1.3, all easy place on a USB stick push reset and power on...few minutes later all done about 5 all up, from go to woe.
Let's have a bit of a look around at the UI and bits it has to offer.
Also a Different App store in use, has some popular item, that are media related, Netflix, Hule, Plex KOdi, and Numerous others and various other Apps and games etc.
APP Store Egreat Style
The More I am using this device I am coming around to its unique interface and how it operates, all good.
MoreToComeLast edited by trebor; 19 November 2016, 13:38.
There is more to the world than Google (believe it or not),
Egreat has a point of difference, and by the looks they wish to support and control this to give the end user the best possible experience
with their product and not have to worry about other possibilities etc.
A brave move in this day and age, a good product for what it can do, not cannot.
It is hard to say what people will pay for a thing. Either they sell enough to make it profitable or they will adopt a new strategy, or disappear.
Not having better WiFi will be an issue for some, but others find the wire more desirable, for those, having G-Bit LAN will be enough.
If this box does what it does well, the addition of USB3.0 and SATA connections could be a draw. Of course, SATA is seen on other, less pricey boxes, but often it is via a USB bridge and may not offer full functionality. Anyone know if this SoC handles SATA natively?
Don't usually see both Optical and Coaxial outputs on a device.
This box does carry a premium, time will tell if it can justify it. It is a little out of my range for any media player/ATV box, but of course, people, their budgets and their needs vary.
This SoC seems to offer a lot. But yeah, the market segment for such a box will be a bit narrower than some.
The shear number of different devices in this arena almost guarantees there is something for everyone.
FWIW I read somewhere that Nougat may come to this box.
Something different for sure... Dts ect all in looks good / no playstore might be a plus for some lol... Hmmmmm. People paid 160 for allwiener... So if it works there will be buyers... 😃Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Another Firmware update today.
The Egeat A5 due to its unique features and interface is becoming interesting to use as everything is not driven by Google so to speak something new and different always to be found.
Rather enjoying this player and what it has to offer,
I have Netflix I have Plex and the Media I have play's with ease.
If your looking for something a little different form the norm this may be the go, and it does have that look.
Its bigger Brother the A10 is as good a looker
Egreat A5 with 1.0.1.7 firmware, be noted it is beta version.
http://www.mediafire.com/file/g85ys0...0.1.7_Beta.rar
Change log:
Blu-ray menu,RAW,TRUE HD 3D playback in Vidon XBMC Pro
Playback Power function
Support .tp format file playback
Fixed some non-standard audio playback in DTS
Suitable icon size on screen when press pause button
Connected external devices no longer work at standby mode with plug in
Upload external subtitle through "open subtitle" when play movie in movie poster
Ensure 4k res. When play 4K res. ts file
Ensure to play main movie in 3D blu-ray navigation menu
No overlay when press "menu" button after pause
There are currently 1328 users online. 0 members and 1328 guests.
