Dispatcher:QuadCoreM9Pro x Finless 1.4 Rom x FreakTab
PIPO M9 - Multi-window/Splitscreen?
Originally posted by PipoM9ProI have been chasing down this for a little while now, so I am assuming no one clue on how to safety and permanently remove the multi-window feature, correct?
Have you considered testing NXMOD ROM? One of its features is the one you are looking for, multi-window removed.
You wont lose them totally tho, you'll gain control by having the Halo pop-up window feature.
If you want to read more look here
In post #7 zloyzopuh gives a download link so you don't have to wrestle with pipo's site and google translate.
Hope this helps.
Originally posted by PipoM9Pro View PostI have been chasing down this for a little while now, so I am assuming no one clue on how to safety and permanently remove the multi-window feature, correct?
With this modification you will delete completly the multi-window but no more hiddable bar...
Look at your build.prop the line "ro.rk.systembar.tabletUI" and change the value to true. Save and reboot. You can try. If you want revert, change the value to false. Save and reboot
You can use the following lines in build.prop
* for split top-notification bar: set ro.rk.systembar.tabletUI=false
* for bottom-notification bar: set ro.rk.systembar.tabletUI=true
* reboot after changing the value.
With the value "true" you will have only the bottom-notification bar (like 4.0 and 4.1 - no top notification bar) and no more hiddable bar .
https://play.google.com/store/apps/d...p.editor&hl=fr
There are currently 1988 users online. 0 members and 1988 guests.
