Anyone have their M6 on the 3g nework?
    I'm looking to purchase the pipo m6 3g. I want to run it on straight talk except i cant get a straight answer as to whether it will work on their network or not. The pipo site lists the 3g function as data only with no frequencies given. Has anyone got there m6 on the 3g network, if so which carrier did you use?
    In the US my M5 3G doesn't support Straight Talk or AT&T. I think wifi is the same on both tablets.
    Randy
    Randy
      A more specific location than "Outer Space" would be useful - otherwise we have no idea what frequency your Straight Talk would be on... If you know the frequency you need - that would be even better.
      Support your local flasher
      Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
        Randy
        Thats kinda what I figured, but I thought I better make sure. Glad I didnt order it first and ask second.
          I suggest you check out what SoC's support your required frequency - then start from there. If find something you like, check that it uses the same radio module as standard for that SoC - and if not, check the new/revised SoC's supported frequencies.
            Pipo M6 3g in Switzerland
            Hi all
            my Pipo M6 (3g version) works quite well over the Sunrise provider here in Switzerland
            Galaxy Note 3 : stock (4.4.2) ROM
            Cubot GT99 : stock ROM with crossbreeder
            Pipo M6 3g : FreaktabROM v1.0.0
              Do you know what frequency and connection that is?
                Not absolutly certain, but I think it is 900 MHz and 2100 MHz in my aerea.
                Hope this helps
