Review Yundoo Y7 1/8GB 905x Amlogic
    Thanks to Gearbest today we have the Yundoo Y7 1/8GB 2.4GHZ WiFi b/g/n
    Quick look at the UI, and installed with Various Players on online stuff
    All Metal Enclosure, Plastic back plate looks OK small unit with only 1/8GB I don't thing it will be to much of a beast
    Vents must be cheap this week nice to see some installed.
    Clock looks good not to bright, small off indication glows when in standby.
    PCB Top Side, Heatsink stuck on good so it can stay, small compact PCB, ribbon cable for front unit display
    Protective Sheet underside to nothing can go zapp
    Not a lot to see on the Under side
    Coupon is ready.
    GBY7
    Only $34.99
    http://www.gearbest.com/tv-box-mini-...08.html?wid=21
    #1
    Gearbest TV Box & Mini PC Page
    #2 Flash Deals Flash Deals
    #3Coupons Coupons, Coupons and More Coupons
      Now for a few benchmark
      Full Detail > http://browser.geekbench.com/v4/cpu/797831
        Been busy but a few more Test and Benchmarks
        Unit is well Built Solid, external wifi Antenna so looking a good Budget box, looks the goods Click image for larger version
        Having only 1/GB, its would be enough for streaming and playing movies etc but don't expect any high performance, and basic gaming ok. Click image for larger version
        FMTC doing its thing Click image for larger version
        Unit does have root but no SU was installed, installed FMTC, as the installed Kodi full of Junk, playing good 4k, some buffer problems with high MB rate files to be expected.
        Netflix Playback Ok not HD but looking ok, as with Plex looking good as usual.
        As mentioned not a world beater, good looking, solid and of course has a clock...
        GBY7
        Only $34.99
          Inserted a 32gb TF Card in the Yundoo Y7
          Format and use as part of the system free up the box. Click image for larger version
          And YT doing its thing...
          Yundoo Y7 1/8GB
          GBY7
          Only $34.99
