HPH NT-N8 RK3229 Review
    Review of HPH NT-N8 RK3229
    Specifications:
    · CPU: RK3229 Quad Core ARM Cortex A7 @ 1.5 GHz
    · GPU: ARM Mali-400MP2
    · RAM: 1/2(Plus) GB DDR3-1866/LPDDR3-1333
    · Storage: 8/16(Plus) GB EMMC
    · Ethernet: 100 Mbps
    · Wifi: 802.11 b/g/n, 2.4G /5G Dual-Band(Plus)
    · Bluetooth: Support BT 4.0
    · HDMI Output: 2.0
    · AV Output: (3.5mm port for tv out or stereo speakers)
    · Audio Output: S/PDIF (2CH, 5.1CH), HDMI Audio via HDMI Out Port
    Supports DTS/AC3 Pass-through, TrueHD, DTSHD, EAC3
    · Memory Card: TF card reader Micro-SD card interface
    (Supports 1GB/2GB/4GB/8GB/16GB/32GB cards)
    Video Codec – 4K2K 10-bit H.265 @ 60 fps (Up to 200 Mbps), 4K 10-bit H.264 @ 30 fps (Up to 250 Mbps) and 4K 8-bit VP9 @ 30 fps (Up to 200 Mbps)
    · Decoder Formats: 10-bit H.264, 10-bit H.265, VP9, AVC, HD AVC/VC-1, HD MPEG1/2/4
    Video Formats: 1080P, 4K x 2K, ASF, AVI, DAT, FLV, M2TS, MKV, MOV, MP4, MPEG, MPG, RM, RMVB, TP, TRP, TS, VOB, WMV, 3D MVC
    Audio Formats: FLAC, MP3, OGG, WAV, WMA
    Picture Formats: BMP, GIF, JPEG, PNG
    · Video Encoder – 1080p H.264 and VP8
    · 4 x USB 2.0 Ports
    · Operating System: Android 5.1
    · Language: Multi Language support
    · Other features: Support DLNA, Miracast, Android/IOS Remote Control App
    · 1080p Youtube Playback Support, Universal Storage
    Package Contents: 1 x TV Box, 1 x EU/US/UK/AU Plug 5V, 3A Power Adapter(correct one will be shipped according to your country),
    1 x HDMI Cable, 1x USB to USB Male Cable(for connecting to PC)
    1 x IR Remote Control, 1 x English User Manual
    There are 2 models
    Specs
    NT N8 - 1GB DDR+8GB EMMC+AP6210 Wifi (2.4G + BT4.0)
    NT N8 Plus - 2GB DDR+16GB EMMC+AP6255 Wifi
    (Dual-band wifi 802ac + BT4.0)
    Top view of the tv box
    Bottom view of the tv box
    There are also rubber pads on the side corners not shown here
    Launcher view
    (If wanting to pay with Paypal just leave the seller a message)
    Airmail
    DHL/EMS
    There are 2 models
    The Plus module has 5G wifi, 2GB RAM and 16GB storage.
    The standard model has 2.4G wifi, 2GB RAM and 8GB storage.
    DRM Info
    The tv box supports Widevine Level 3 DRM.
    Antutu Benchmark Click image for larger version
    5.8 GB Unified Storage
    I will try to see if I can push it over 6GB. Click image for larger version
    Geekbench 4.0.1 Scores
    (Not to be confused with other RK3229's that was tested with Geekbench 3.4.1 that will result in different scores) Click image for larger version
    Vellamo Score
    (Not to be confused with other RK3229's that used an older version to test) Click image for larger version
    Easy Root/Unroot Setting Click image for larger version
    LeHome Remote Control Android app Screenshots Click image for larger version
    1080p Youtube Support Click image for larger version
    Some video playback tests.
    All tests were done on a 1080p LED tv.
    Results may vary on a UHD 4K display.
    VC-1_29.970_sample.mkv
    Plays smooth and deinterlacing is supported
    PUPPIES BATH IN 4K (ULTRA HD)(Original_H.264-AAC).mp4
    Smooth playback
    MPEG2_1080i_sample.mkv
    Smooth playback
    Elysium_trailer_1-4K-HDTN(4ksamples.com).mp4
    Smooth playback. There are just a few frame drops at one scene at the beginning of the video.
    ed24p_03.ts
    Smooth playback
    dothack2.mpg
    Smooth playback. Mpeg 2 playback is supported which was a problem a few months back on RK devices.
    BT.2020.20140602.ts
    Smooth playback. This kind of video format is not generally working on a lot of devices.
    big_buck_bunny_720p_MPEG2_MP2_25fps_3600K.MPG
    Smooth playback
    big_buck_bunny_4k_H264_30fps.mp4
    Smooth playback
    Beauty_3840x2160_120fps_420_8bit_HEVC_MP4.mp4
    Smooth playback. Some other RK3229 devices have problwems playing this back.
    [07_REF_L4.0]Sword Art Online BD Opening.mkv
    Smooth playback. Good to know 10-bit H264 anime is working properly.
    [16_REF_L5.1][mp3_2.0]Suzumiya Haruhi no Shoushitsu BD OP.mkv
    This video froze at the beginning of playback. I read that the RK3229 chipset doesn't support Ref16 Hi10p h264 playback.
    Luckily most videos aren't in this format and most 10-bit anime is still playable.
    4K-Chimei-inn-60mbps.mp4
    Smooth playback
      Hi mo123 Is it possible to get a copy of the launcher for my HPH?
      kind regards
      cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
      http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
        Yes
        I will try to make new firmware for HPH NT-V6 & HPH NT-V8 with this new launcher.
        NTMC also has been heavily updated, so video playback will be better.
        If taking too long, I will just send you the new launcher later.
          Hello mo123, How are the temps?
            I think it was 65C, can't remember if I saw it in Kodi after testing some videos.
            But the outside of the casing didn't feel hot just slightly warm on the bottom.
            Will play some 4K videos for an hour and then check temp again.
            Is there a reliable way to test the temperature with an app perhaps or is the Kodi temp reporting accurate?
            What are the temp on other RK3229 devices, do you know?
            I heard the RK3229 CPU can reach a high temp of around 120C and read the temp on MX & R-box RK3229 was about 93-96C.
              You can see some temps reflected in the benchmark screencaps in Trebor's R-Box post, scroll to just under the teardown pics.
              If I remember correctly, on the R-Box, Kodi reads higher, than indicated elsewhere. As well as, versus IR to heatsink.
              She uses that box and I don't get much time on it these days. I will try to check the temps next time I do.
              See if CPU-Z conflicts with Kodi temps.
                CPU-Z doesn't seem to show the temperature.
                I will see if I can do a terminal command to get the temperature.
                I think it will be something like cat /sys/class/temp0 or something.
                Some more pictures uploaded to post #2.
                  It would be a good idea for Nagrace to update their website to show that their new product exists and is for sale.
                    They are planning to update the whole site.
                    But I will ask if they can do it sooner
                      AWESOME mo123
                      When do you think you will release the new OS/Launcher for the V8?
                      kind regards
                        AWESOME mo123
                        I will see if I can update the HPH NT-V8 firmware in the next 2 days.
                        Include the new launcher and update NTMC(Kodi).
                          New shipping methods added:
                          If you are in the US the parcel can ship with E-Packet which is an expedited shipping method.
                          For other countries airmail will be used.
                          Price will then be $39.99 for the 1GB/8GB device.
                          https://www.aliexpress.com/store/pro...761092347.html
                          For DHL shipping the 1GB/8GB device is $45.90
                          For the Plus model, it is recommended to use DHL shipping since there is only a limited quantity still available.
                          https://www.aliexpress.com/store/pro...750590406.html
                            Marshmallow firmware for HPH NT-N8 supports auto frame-rate switching in Kodi & stock video player for improved video playback smoothness
                            I will test Netflix, Antiutu and the latest Kodi soon and upload some screenshots.
                            Final MM firmware hopefully finished by next week.
                              Some new screenshots of Marshmallow running on HPH NT-N8 RK3229 tv box. Click image for larger version
                              Antutu score increased a bit
                              Now I just have to find a way to root it, lol.
                              Root will be added next week with other improvements.
