Hard reset V88 Pro
Originally posted by scooter2014 View PostYou have to reboot into recovery or sd card. Back port will connect as soon as you plug it inti pc. To flash ezroot via sd card use software up date in firmware.
YOu need to use an A to A cable. http://www.gearbest.com/cables-conne...02.html?wid=21 and you need to install the ami-logic burn tool. If your computer is not seeing it, then you need to short out the pins on the board. Kevin posted a picture in the other thread. You can use a small screwdriver or paperclip. It must be done while plugged in to your computer to force it to recover mode.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hmmm then you flash from previous port to the last one? Must be on stock because flash this one shows brick on tool can't see without short pins? This I trying correct but learning curve for me looking at boot
Originally posted by jakotaki007 View PostGuys,
Do you know which pins i must short out with this nand?
I'm trying everything and usb not recognise my device ( V88 Pro )
Regards
Guys, which USB Tool are you talking about?
I have a version 2.0.5.15 and it runs but no english text. Can't understand F all.
Ok, found 2.0.4.3 which is in English so I can proceed.
File here if anyone needs it..
https://1drv.ms/u/s!AjdwqumIpI5i6ATzUeYnVLSD789w
And if anyone can confirm if they get the following attached error or not please...Last edited by KBL; 26 April 2017, 12:56.The Case for Reform
Drug Science Prof D. Nutt
The life of a good person means more to me than that of a bad person.
I have no borders as far as good people go.
Originally posted by Kuno View PostYOu need to use an A to A cable. http://www.gearbest.com/cables-conne...02.html?wid=21 and you need to install the ami-logic burn tool. If your computer is not seeing it, then you need to short out the pins on the board. Kevin posted a picture in the other thread. You can use a small screwdriver or paperclip. It must be done while plugged in to your computer to force it to recover mode.
There are currently 2704 users online. 0 members and 2704 guests.
