Which amlogic s912 with best support
Beelink have showed their cards so far and it's pretty good as have many others, and support is there also.
Plenty of good Media Players to be found on Freaktab.
There is still a few to bare all,
The S912 boxes that have arrived so far pretty much seem to have the same performance and basically the same firmwares with different launchers stuck on them, so might well be worth waiting until the dust settles and more boxes to arrive.
The RK3399 is just around the corner too, so it might even be worth holding off for a few weeks to see what that offers as it might just be a serious competitor to the S912.
Now you got me thinking the new rk3399 has a better gpu. I think I will wait, any idea when a box will be available?
Hey I see you got a asrock beebox n3150 me too. I'm just running openelec on it at min I'm only running at a resolution of 1080p 60 as 4k only has 2 settings which both seem to be a little jerky on playback.
Originally posted by avd View PostNow you got me thinking the new rk3399 has a better gpu. I think I will wait, any idea when a box will be available?
I'm running a dual boot on my Beebox with Windows 10 and this
Jerky playback can be due to only having 1 stick of RAM, with 4k, so utilising the dual channel memory will remove the jerky playback.
Thanks for info. Im running dual channel memory 2 x 4gb. It is not jerky all the time just say if the camera was panning and there will be a judder every so often. I dont know if it is an issue with my 4k tv as it is running at 60hz and i can only choose 23 or 24 at 4k resolution.
What are the advantages of running that other build of kodi on ubuntu server?
Originally posted by avd View PostThanks for info. Im running dual channel memory 2 x 4gb. It is not jerky all the time just say if the camera was panning and there will be a judder every so often. I dont know if it is an issue with my 4k tv as it is running at 60hz and i can only choose 23 or 24 at 4k resolution.
Updates are handled with a couple of simple commands too.
But worth asking the same question of fritsch, the dev that came up with it as he would give you a more detailed explanation.
There are currently 2176 users online. 9 members and 2167 guests.
