[4K Ubox R89] Moded external WiFi Antenna
    Yo everyone, so after a while not using my box (about 6 month), i wanted to check it, and it was in pretty bad shape. I had done some weird stuff to it LOL. But since i really liked this box (and i got it since it's release in 2014, some linf of emotional bound), i decided todo something about it. I put it back together. But i have an old house with super thick wall and WiFi signal was bad, so i soldered a new wifi antenna with pigtail at the end of it, i drilled a hole on the plastic shell and glued it. Then you can screw in a pc antenna and the signal is so damn good! And with the update of wasser, everything is perfect. Here is a pic!
    BTW, i drilled the big square hole at first because i had put a fan on the heatsink, and the hole was to ventilate, it worked, but wasn't necessary. So i removed it and covered the hole with an old prepaid mastercard. And i did a diy button and led because i broke the old ribbon cable! But now it looks freaking hard core
    Hi GFG99
    I can not open your picture.I really want to see how you did that.Can you please upload maybe here.Take the"Foto für Foren"Link and copy to the Thread.
    Example
    url=http://www.fotos-hochladen.net][/url]
    have a nice Day
    gefattern
      Awesome........ thanks for the pics.
        Clark i know you spent alot on boxes but to weld your credit card into box that pure genious... love it.
          Hey gefattern, i upload it via your site right away!
          Clark and Scooter, really glad you enjoid it LOL, the real advantage is how the wifi is strong, and all you need really is a bit of soldering skills and something like those (wifi antenna pigtail)
          Then denude the antenna cable, separate the outter metal wire for the inner metal wire and solder it on the 2 spots of wifi antenna on the motherboard!
            If you're interested i can make internal pictures too
              Hi GFG99
              Yes please helps me for future Mods.
              nice Day
              gefattern
                Well Full CREDIT for your modification, first real PAYBOX I think
                  no problem gefattern. LOL trebor
                    Hi GFG99
                    Can you please upload the internal Picture,thanks.
                    nice Day
                    gefattern
                      Hey Gefattern, i'm out until sunday and i forgot to take the pictures with me so i will post them on sunday
                        Hi GFG99,
                        Okay
                        nice Day
                        gefattern
                          Heey gefattern, i didn't forget you
                            Hi GFG99,
                            thanks for the upload,not bad,really.
                            nice Day
                            gefattern
