Connecting the tvbox to Internet by Ethernet port, and enable portable hotspot function. While someone is downloading something via this portable hotspot function, any other network activity on tvbox itself will cause the tvbox crashed (e.g.: watching online tv, wget something ). That means the portable hotspot function cannot work simultaneously with the tvbox itself.
It is identified as kernel panic:
[ 219.794452@0] BUG: failure at /home/qinrq/work/s905-2/common/include/linux/skbuff.h:1891/skb_orphan()!
[ 219.798117@0] Kernel panic - not syncing: BUG!
[ 219.802497@0] CPU: 0 PID: 4843 Comm: dhd_dpc Tainted: P O 3.14.29-g494844a #31
[ 219.810512@0] Call trace:
[ 219.813110@0] [<ffffffc001088e74>] dump_backtrace+0x0/0x144
[ 219.818625@0] [<ffffffc001088fd4>] show_stack+0x1c/0x28
[ 219.823799@0] [<ffffffc0019ada20>] dump_stack+0x74/0xb8
[ 219.828973@0] [<ffffffc0019aaec8>] panic+0xe8/0x20c
[ 219.833826@0] [<ffffffbffc0e5d30>] dhdsdio_sendfromq+0x1b8/0x470 [dhd]
[ 219.840295@0] [<ffffffbffc0e9e30>] dhd_bus_dpc+0x2e4/0xed4 [dhd]
[ 219.846241@0] [<ffffffbffc0c0b94>] dhd_dpc_thread+0xf4/0x184 [dhd]
[ 219.852350@0] [<ffffffc0010bdd94>] kthread+0xd8/0xf0
[ 219.857268@2] CPU2: stopping
[ 219.860115@2] CPU: 2 PID: 4912 Comm: Thread-206 Tainted: P O 3.14.29-g494844a #31
[ 219.868387@2] Call trace:
[ 219.870984@2] [<ffffffc001088e74>] dump_backtrace+0x0/0x144
[ 219.876495@2] [<ffffffc001088fd4>] show_stack+0x1c/0x28
[ 219.881672@2] [<ffffffc0019ada20>] dump_stack+0x74/0xb8
[ 219.886846@2] [<ffffffc0010902f0>] handle_IPI+0x194/0x1a4
[ 219.892192@2] [<ffffffc001081454>] gic_handle_irq+0x80/0x88
[ 219.897711@2] Exception stack(0xffffffc0636b7eb0 to 0xffffffc0636b7fd0)
[ 219.904268@2] 7ea0: 00000000 00000000 00000000 00000000
[ 219.912548@2] 7ec0: ffffffff ffffffff f7016c50 00000000 ab3ba068 00000000 ab4cfb78 00000000
[ 219.920827@2] 7ee0: 07000007 00000000 00000000 00000000 00000004 00000000 ab4cfd40 00000000
[ 219.929107@2] 7f00: 00000007 00000000 00000034 00000000 def1e6c8 00000000 f71ef750 00000000
[ 219.937388@2] 7f20: def1e700 00000000 f14de5ec 00000000 f71fbcc0 00000000 def1e580 00000000
[ 219.945667@2] 7f40: f71757f7 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.953947@2] 7f60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.962227@2] 7f80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.970507@2] 7fa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.978786@2] 7fc0: 00000000 00000000 00000000 00000000
[ 219.983960@1] CPU1: stopping
[ 219.986808@1] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P O 3.14.29-g494844a #31
[ 219.994740@1] Call trace:
[ 219.997331@1] [<ffffffc001088e74>] dump_backtrace+0x0/0x144
[ 220.002851@1] [<ffffffc001088fd4>] show_stack+0x1c/0x28
[ 220.008025@1] [<ffffffc0019ada20>] dump_stack+0x74/0xb8
[ 220.013200@1] [<ffffffc0010902f0>] handle_IPI+0x194/0x1a4
[ 220.018548@1] [<ffffffc001081454>] gic_handle_irq+0x80/0x88
[ 220.024067@1] Exception stack(0xffffffc0633d7e20 to 0xffffffc0633d7f40)
[ 220.030624@1] 7e20: 633d4000 ffffffc0 633d4000 ffffffc0 633d7f60 ffffffc0 01085458 ffffffc0
[ 220.038904@1] 7e40: 010f1e5c ffffffc0 00000000 00000000 7a1b1cbc ffffffc0 00000000 01000000
[ 220.047184@1] 7e60: 01e1e720 ffffffc0 7d000000 00000000 25c17d03 00000002 1fd55290 00000000
[ 220.055464@1] 7e80: 00000015 00000000 633d7d80 ffffffc0 00000400 00000000 000003f0 00000000
[ 220.063744@1] 7ea0: deb0e928 00000000 deb0e918 00000000 f5744697 00000000 00000000 00000000
[ 220.072024@1] 7ec0: 0110e4e0 ffffffc0 00_
The similar bug was found in similar s905 tvbox minix U1, however the minix had released firmware to fix this issue, will ACEMAX fix this issue ?
