the device should use the powerful 28nm RK3188 quad core GPU,
with 2GB RAM and 8GB storage.
Operating system with android 4.2.2 is better,
the most important thing is it should got very good wifi signal,
I bought a dual core mini pc before,
the wifi signal is very bad,
I found the cx-919
with external wifi antenna,
that makes it got better wifi signal,
Let's take a close look at this mini pc on youtube
