Sunvell T95K Pro Android 6.0 2/16gb Gig Lan, Dual WiFi, BT4
    Amlogic S912 Octa-core CPU Supporting KODI 16.1 Dual Band WiFi Bluetooth 4.0 Connectivity
    If you need more
    colour in your life then this is for you.
    The Mondrian look I think its called, well close
    Gearbest
    Looks like a Rubik Cube! Not bad.
    Cheers
      Sunvell T95K Pro
      Coupon code: GBT95KP
      Only $58.99
      Coupon is ready
      #1
      Gearbest TV Box & Mini PC Page
      #2 Flash Deals Flash Deals
      #3Coupons Coupons, Coupons and More Coupons
        Yes Good to see some Media Players showing a bit of colour black is so yesterday unless it's Piano Black now that's a sharp look.
        Cheers
          Pretty wild look. Reminds me of the Partridge Family bus. Good to see a break away from the ubiquitous black box.
            A Colourful looking unit, may be a little loud for some but if colour is your want than this may be for you.
            Have a look on the inside first to see what we have, Small PCB Samsung Ram, Kingston Emmc, Heat Sink on solid will see how it goes.
            Underside of the PCB as always not much to see here.
            Close of this bits that make it al happen
            Rather Bright again LED can change colour pity not more like the advertised image
              Test and Benchmarks etc.
              A fairly typical Sunvell media player, bootup animation etc, same ui's and performance is also pretty much good as most of these Sunvell players appear.
              Not much air circulation to be found and temps not over the top so far, so it could be an ok unit a few days of torture will find that out.
              DRM Info L3 fairly standard.
              Full Details > http://browser.geekbench.com/v4/compute/226792
              Performance while running test overall nothing appeared out of place and all was as it should be, bit of performance with ram speed, WiFI and Ethernet speeds good at this location, and the overall performance much the same as other 912,
              The Colour may put some off, with the mass of Black boxes about it is different.
              Why they bothered with the one coloured Indication Led that can change to the standard Blue, Light blue and Green I don't know yet.
              A Good unit if you're looking for something a little different.
              I will stress it out a bit next day or so and report any bad,
              Unit does have root.
                IS the update button supported ?
                  Sunvell Media Players do support OTA updates nothing as yet for this one.
                  There is a rest button Behind AV port.
                  Most of this make and there are a few about on Freaktab have been OK, like most others,
                  They all can start a little rough, a little TLC from Freaktab usually gets most media players sorted.
                    First Boot Startup Animation T95K Amlogic 912 2/16Gb Dual WiFi Gig Lan BT4
                      Here is the firmware.
                      feel free to download it
                      #1
                        If you're not happy with the mixed up colour look of the Base different to the Top you can alter the tiles for a les OCD look, a individual thing of course Click image for larger version
                        Had good fiddle last week with this unit and its doing well, bit of a clean out of the Junk, running FTMC instead of Kodi does all I need it to do, easy
                        and of course the colour, good to see a bit of difference.
                        Yet to check out firmware above, pretty happy with what it can do at present but will have a look just the same
                        Just checked and is the same version that is installed
                          I am considering cutting a hole in the top of the case to allow a large PC heatsink to fit, is the heatsink built into this device facing upright when you open the case? Would be a problem if it was facing the bottom (unless I ran it upside down and cut a hole in the bottom)
                            Just improve air circulation should work fine....
                            Holes around the edge say in the black area small ones and a few on the Base and sit atop a cheap laptop cooler.
                              Hmm yes a laptop cooler should do the job just as well.
                              Wonder if there is anywhere to conveniently pull the power for a fan from on the board.
                              Then could use a rom with 2ghz unlocked... would be nice i bet.
