OpenElec 7.0 for Beelink X2 H3
When i insert the sd card after a while i see the openelec logo and after 2-3 mins the device shuts down. after i remove the power plug and put it again openelec bootup but after a while the box freezes. i tried to check and fix the second partition with gparted as told here but also the same the box freezes. When openelec freezes it destroys the second partition and does not boot anymore. any solution?
Hi triiharas, I had to same problem and I had to install the X2 firmware thru usb and all was good again.
Here are the links to firmware and information.
I found the X2 too slow for me when I had openlec and linux working on this box so I only use it with new firmware I linked you to.
Cheers I hope this helps.
Kevin
There are currently 2302 users online. 0 members and 2302 guests.
