T95X TWRP/Xposed
    T95X TWRP/Xposed
    Hello freaktabbers I was wondering if there is a way to install xposed and or TWRP on my box. I have the 2/8 version. Thanks
    Figured it out... hahaha
      Hello dutchmaster
      How did you do it ?
        Yo can use flash flash tool to like rashr to install twrp. Then use twrp to install xposed. Went smooth.. Would you like files or the exact steps
          Is it the procedure explained in this thread, post 19?
            No its much easier. Give me a minute as I'm cooking dinner. If you'd like I can make a video.
              It's very easy as posted but if you have an easier way then that will be great to know and by all means make a video as people can see it in action too
                https://youtu.be/UZMS8qYs2tQ the files needed will be in the description. IF there is anything else i hope im able to help you with it
                  https://youtu.be/UZMS8qYs2tQ the links to the files are in the video description. Let me know if i can help any further
                    Thanks for that.
                    A nice easy method to follow and Rashr looks like a great utility to have.
                      Thanks for that.
                      Not bad at all but I could only get it to flash .IMG files. Not any .zips
                        Thanks. Just to be sure. You have a T95x S905x box running MM ?
                          Yes and yes..
