New firmware ZIDOO X9S V1.2.6 Released
    Zidoo x9s new firmware: Soon
    v1.2.6
    Issues Fixed:
    1,The playback of video get stuck after aging test of audio playback, which is in the situation that the box connected to receiver and meanwhile HDMI out set to RAW.
    2,Video <Grand Canyon.mkv>(VP9 VBR-fps) lost frames when playback.
    3,Video<Crouching Tiger Hidden Dragon> show green screen when playback.
    4,Repeatedly playback through the tag of Html5, may lead to system crash and green screen.
    5,Some apk for root were prohibited to install.
    6,Failed to set FIX IP and PPPOE.
    7,Unexpected restart happens when close the CEC.
    8,Some 3D MVC stutter on playback.
    9,Sometime unexpected power on in spite of the CEC was off.(Now turn off the CEC AUTO POWERON)
    10,PPPOE failed to log in.
    Enhancements:
    1,A Picture parameter adjustment function added into Setting of system
    2,For 4K TVset,Set 1080P/60hz as a default option in the HDMI AUTO of the Settings.
    3,A option that permanently close the subtitle added in the native player.If you selected this option,the subtitle will never come out anyhow.** to be confirmed**
    4,A icon in PiP window to mute audio added.
    5,The MP4 format added to record function in HDMI IN.
    6,The arrangement of apps in the Apps list enriched,there are 3 ways which are alphabetical,installation time and usage frequency to reorder apps.
    7,2160P50Hz mode added.
    Source Ziddo Forum
    Issues Fixed:
    1,The playback of video get stuck after aging test of audio playback, which is in the situation that the box connected to receiver meanwhile the HDMI out set to RAW.
    2,Solved some VP9 4K@30p files has minor judder.
    3,Video<Crouching Tiger Hidden Dragon> shows green screen when playback.
    5,Some Apks use for root were prohibited to install.
    8,Some 3D MVC MKV's stutters on playback.
    9,Sometime unexpected power on in spite of the CEC was off.(Now turn off the CEC POWER ON FROM TV will be OK.)
    Enhancements:
    1,A Picture parameter adjustment function added to Setting of system and Native player.
    2,A option that close the subtitle added to the native player.If you selected this option,the default subtitle setting will be "off" anyhow
    4,A icon added in PiP window to mute audio.
    Model:ZIDOO_X9S
    VERSION:V1.2.6
    CHANGELOG:
    Issues Fixed:
    Enhancements:
    3,A icon added in PiP window to mute audio.
    4,The MP4 format added to record function in HDMI IN.
    5,The arrangement of apps in the Apps list enriched,there are 3 ways which are alphabetical,installation time and usage frequency to reorder apps.
    6,2160P50Hz mode added.
    7,Frame rate auto switch 2160P50HZ added
    8,Auto-switching to 3D mode for HALF 3D files,If the filename contains "3D" and "HSBS" or "HOU" or "HTAB" or "H.SBS" or "H.OU" or "H.TAB" or "H&U"
    About Proper playing MVC MKV's to framepacking,In completely rewriting about this, it takes some time.
    Will add Aria2 and webui-aria2 in version v1.2.7
    Full_OTA_Package:
    Mediafire mirror:http://www.mediafire.com/file/b3v0l8...OTA_v1.2.6.zip
    Amazon mirror: http://ota-cloudfront.zidoo.tv/X9S/O...OTA_v1.2.6.zip
    MD5:f897c98d38d7b7bea5ff2b31873d09fc
    How to upgrade: http://www.zidoo.tv/Support/guide/guide_target/7kv1voas1D1KKmVViAFMcQ==/guide_faq/CN6lY0XMyIg=/faq_page/9nCdOWqz+dw=.html
    Some changes on v1.2.6
