Linux Images for S802 S805 S812 S905 S905X S912 (SD USB eMMC)
The new version Armbiam 20190825 kernel 5.3.0. In this version the temperature display on G12 works.
For reasons not yet clear, the G12 has a conflict with this kernel with PULSEAUDIO. To turn the sound on models with G12 (s905x2 S922x a311d) you need to perform these steps.
1. Remove package "pulseaudio".
2. Reboot the system.
3. Once run the command "sudo /root/g12_sound.sh".
When you remove the pulseaudio package, not volume control.
Alternatively, you can install the "pnmixer" package that works with ALSA.
Khadas VIM3 and Ugoos AM6
Full-screen 1080p video playback from Youtube (Chromium) to works at a temperature no higher than 55 (without a fan).
Pay attention. The multi-boot scripts have been updated, I recommend to re-activate the multi-boot using the new scripts. In the scripts added ability to run Android without removing the external media Armbian. To do this in the first section of the external media (/boot) to create an empty file boot_android. If you have this file, each time you restart, either the external system or Android from eMMC will start in turn. To disable this mode, you need to delete the file boot_android external media.
To configure dtb and this can be used on all S9xxx.
I received an AM6 sample yesterday. :) This weekend I will try to do General tests with the Android firmware that is now in it. I warn you right away, I'm not interested in Android and I do not use it, so write questions and detailed steps that you want me to try to perform in the standard Android firmware on AM6. My goal is
The start system in Coreelec is not compatible with LibreELECE Armbian etc. If you run coreelec on your TV box, you will no longer be able to run LE and Armbian normally until the full recovery of the standard firmware via the USB Burn Tool and the new activation of the universal multi-boot, which is used in all new systems.
New image 5.96 kernel 5.3.0-rc8.
For G12 models, stereo sound now works.
I pay attention, DTB by default changed. Now is set DTB default Ugoos AM6.
There are currently 2467 users online. 1 members and 2466 guests.
