Sunvell T95V PRO TV Box Android 6.0 2/16GB Dual WiFi Gig Lan BT4
Thanks to gearbest we can have a close look at the
Sunvell T95V PRO Portable Android 7.1 OS Octa Core Amlogic S912 WiFi 2.4G + 5G Bluetooth 4.0
Better late than never this one has been about for awhile let's see what we have:
SpecificationThe BoxBrand: Sunvell
Model: Sunvell T95V PRO
Type: TV Box
System: Android 7.1
CPU: Amlogic S912
Core: Octa Core
GPU: ARM Mali-T820MP3
RAM: 2G
RAM Type: DDR3
ROM: 16G
Maximum External Hard Drives Capacity: 500GB
TV Box Features: 5.1 Surround Sound Output
Color: BlackDecoder Format: H.263,H.264
Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B,WMV
Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
Photo Format: BMP,GIF,JPEG,PNG,TIFF
Support 5.1 Surround Sound Output: Yes5G WiFi: Yes
Bluetooth: Bluetooth4.0
Power Supply: Charge Adapter
Interface: AV,DC Power Port,Ethernet,HDMI,SD Card Slot,USB2.0
Language: Multi-language
DVD Support: No
HDMI Version: 2.0
Other Functions: 3D Video
External Subtitle Supported: NoSystem Bit: 64Bit Power Type: External Power Adapter Mode
Power Adapter Output: 5V 2AProduct weight: 0.2500 kg
Package weight: 0.5050 kg
Product size (L x W x H): 13.00 x 13.00 x 3.00 cm / 5.12 x 5.12 x 1.18 inches
Package size (L x W x H): 22.00 x 14.00 x 6.00 cm / 8.66 x 5.51 x 2.36 inchesPackage Contents: 1 x Sunvell T95V PRO TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
What's in the Box
Base
Ports Rear
Ports Side
Remove the Lid
Remove PCB, Red jumper wire Interesting ?
Top Side
The Other side
Ram and eMMC and Wifi
GearbestLast edited by trebor; 05 February 2018, 08:12.
This is the most overheating BOX as I ever seen. CPU tempurature about 80-85°C in standard using. Do not buy this box if you want to flash and can not solve own heatsink. I attach my solution to solve this box:You may only view thumbnails in this gallery. This gallery has 9 photos.9 Photos
Originally posted by mXHX View PostThis is the most overheating BOX as I ever seen. CPU tempurature about 80-85°C in standard using. Do not buy this box if you want to flash and can not solve own heatsink. I attach my solution to solve this box:
Originally posted by sabre66 View Post
Hi, can i take it from the last photo that you use Ugoos AM3 firmware on this unit. I am looking to flash to 7.1.2. Nice review, thanks for pics
I have exactly the same box and it's bricked.
Have only green light, no signal on tv and pc don't recognized it.
I found which two pins to short and usb burning tool did recognized it after.
Can anyone suggest any rom to flash, I tried 2-3 that i can found but always stop at 7%, formatting error.
There are currently 1390 users online. 0 members and 1390 guests.
