Nomu S10 REVIEW BY NEOMODE
    NOMU S10 REVIEW
    NOMU S10 Technical Specifications:
    BRAND NOMU
    MODEL S10
    COLOR BLACK / ORANGE
    DIMENSIONS 146.6x75.9x13.95 mm
    WEIGHT 221.5g
    MATERIAL Aluminum titanium combined bracket
    TYPE 3-proof Phones
    TECHNOLOGY IP68 Waterproof over 1.5M and 30 minutes
    Drop test (1.5M Shatter-Resistant)
    Working Temperature:-20℃~55℃
    PROCESSOR
    CPU MTK6737T 64bit Quad-core 1.5GHz
    GPU Mali-T720
    OPERATION SYSTEM Android 6.0 Marshmallow
    RAM 2GB DDR3
    ROM 16GB
    BATTERY 5000mAh Li-Po Built-in
    QUICK CHARGE 5V/7V/9V~2A
    STANDBY TIME 580 Hours
    DISPLAY
    DISPLAY SIZE 5.0 inch
    RESOLUTION HD 720x1280pixels
    TECHNOLOGY Corning Gorilla Glass 3
    Sharp® IGZO
    Multi-touch - 5 capacitive points, OnCell
    178° View Angle
    1000/1 Contrast Ratio
    500cd/m² Luminance
    84% NTSC Color Gamut
    CAMERA
    REAR 8.0MP ( Interpolation to 13.0MP ) Sony IMX219
    5 lenses
    Single flash
    Phase Detection Autofocus (PDAF)
    Fast motion and Time Lapse
    HDR
    Capture in RAW format
    Parameters’ manual setting (shutter speed, focus, ISO)
    Panoramic mode
    FRONT 2.0MP(Interpolation to 5.0MP)
    3 lenses
    Aperture ƒ/2.4
    Selfie Indicator
    Video resolution 1080p@30fps
    CONNECTION
    BAND 2G GSM:850/900/1800/1900(B5/B8/B3/B2)
    3G WCDMA:900/2100(B8/B1)
    4G FDD-LTE:800/900/1800/2100/2600(B20/B8/B3/B1/B7)
    TDD-LTE:2300(B40)
    SIM CARD Dual sim Dual standby
    Or 1 Micro SIM Card and 1 TF Card
    Both SIM slots are compatible with 4G, respectively.
    When they work at the same time, only one of them can receive
    LTE service and the other GSM.
    Default at slot 1
    MICRO SD CARD Up to 32GB
    WIFI IEEE 802.11 a/b/g/n 2.4GHz
    BLUETOOTH 4.0 BLE
    GPS GPS&AGPS,Glonass
    EARPHONE PORT 3.5mm
    OTG Yes
    SENSOR
    Gravity sensor, Brightness sensor,
    Proximity sensor, Accelerometer,eCompass
    NOMU S10 HARDWARE
    The NOMU S10 is a rugged phone that stands out with his design.
    His look is different without round edges what give him a different look to other phones.
    It´s main color of the phone is black with an orange frame around the screen also on the back.
    You found the following connection points on the phone earphone USB OTG and the MICRO SD-CARD / SIM CARD SLOT.
    All these connection points are properly closed with a lid, the lids itself you can not lose cause they are fixes to the
    main phone body. This is a very good Feature. Also, I can not found any gap on the Phone.
    So you can use the NOMU S10 like you want, take it with you and it will be on your Side.
    The NOMU S10 is Certified to IP68 and Military Grade on the Drop Down Test and Waterproof.
    We tested it and yes the Phone is Waterproof !
    If you want to Play Music with the phone over the loudspeaker you will be surprised. It is very loud for a mobile phone.
    Even the quality of the sound is very good also when you play it loud. Overall it has a good harmonic sound feeling.
    The Sharp® IGZO display in the phone offers you a really good picture quality with a wide viewing angle and his
    brightness is very good and for the protection of the Screen, you can count on the Gorilla Glass 4.
    For pictures, you have a build in camera with 8 MP Hardware with up to 13 MP with a Sony IMX219 sensor.
    The quality of the pictures is ok for that camera when you make pictures in the wild.
    Inside photos are a little bit dark but still ok.
    Battery life is always a point on smart phones, but not on the NOMU S10.
    It comes with a 5000mAh Li-Po battery, this battery gives you 2 days of lifetime on it. I use my phone for
    Mail, Skype, Hangouts, and other battery draining applications and it gives me enough battery life during
    the day without recharging.
    The phone has a MTK6737T 64bit quad-core CPU with up to 1.5GHz. It have enough power to handle your
    apps without any waiting time. Even with Skype, YouTube or small games, the phone did not get hot.
    Overall a good performance. Antutu shows a score of 36500 points.
    For the Wi-Fi Chip inside I can say it runs very good and give me up to 43 Mbps on FAST speed test.
    Mobile Network works also perfect even on LTE all Bands are covered with LTE Speeds up to 50 Mbps in my area.
    GPS support GLONAS, NAVSTAR also AGPS.
    The position fix is very fast after that you get a very good GPS positioning.
    NOMU S10 SOFTWARE
    The NOMU S10 is powered by Android 6.0.
    NOMU also release a first update to the phone you can find here:
    NOMU build a standard Android 6.0 ROM without any bloatware on it.
    All over it is a good Vanilla Rom.
    They also build in some nice features like:
    TURBO DOWNLOAD
    With this feature, you can download faster on your Wi-Fi cause they are
    enable also the LTE network to download from.
    MIRA VISION
    For best visual effects.
    NAVIGATION BAR
    You can change the Back Button of the navigation bar from right to left.
    Very good feature.
    Overall good Work on the Rom from NOMU. No resets or wait Staits.
    Even Google Play Store works perfectly.
    RESUME
    The NOMU S10 is a good rugged phone for the price.
    Outstanding with design and battery life and software.
    I did not find any problem with the phone during the Test.
    So if you need a new phone you should get the NOMU S10.
    For it´s Price of 129 USD it gives you all what you need and more.
    Ask yourself, where you get a rugged phone with these good features for that price?
ID:	606621 Click image for larger version
ID:	606622 ​​​​​​​ Click image for larger version
    Nice....
      Link to buy?
        Here is a Buying Link
          Hello, i have this phone and i was wondering if the new S10 Pro with android 7 firmware would work on this one as well since all i can see in the differences is that the new one has 3 gigs of ram and double the memory.. The rest is all the same (i think)... Thanks for any help on this issue..
            Last week, I upgraded the phone to Android 7.0 version. I feel the phone is much better after the upgrading. The speed is faster, and running more smooth, the UI is more beautiful. I love it more.
