Which box i have,T95N or T95X.On the board is mark T95X.
From a quick google search ... the T95N is S905 (and running Android 5.1) and the T95X is S905X (and running Android 6.0)
I have a Mini M8S II S905X (brand on the case is COOLEME but it's a Mini M8S II on the circuit board) ... Stock Kodi (Jarvis) works fine with 4K ... but
am running LibreELEC (Kodi) from SD ... Android Kodi doesn't support Auto Frame/Refresh Rate Switching ... LibreELEC does
Yes,T95N need to be S905,but on my board is T95X mark together with S905X4 2G V01 stamp on the board.
My T95N have 6.0.1 android without bluetooth,and Kodi do not works fine on any 4K files.
Does i need to find some T95X firmware on which Kodi will works fine,and where to find it?
My android Bulid number is:T5X10004.
Device [P212}
Model is:MBOX.
I have installed firmware from your link but still fail to turn wifi on
About ur remote, try this file http://www.mediafire.com/file/k7vkb3...na/remote.conf
There are currently 1616 users online. 0 members and 1616 guests.
