Base image for k6000 pro
    Can we request for base android firmware available on the devices?
    Are there any updates expected on the devices?
    I see that there are some minor issues for incoming calls with this device.. Apparently device stops ringing and only shows on screen for incoming calls..
    Is there any solution to this issue?
    Sent from my iPad using Tapatalk
    Dear Oukitel Team,
    Looking at the performance and hardware stability to withstand the peak performance I have ordered K6000 Plus as well. But it will be really nice if you could share some official links for base images. We can always get back to original state using backups but can't do much unless you share the stock firmwares.
    Will it be possible for you to release the firmwares?
    Atleast let us know.
    My earlier post got more than 69K views only because of wonderful device performance.
    Thank you.
    Regards,
    Sarvesh
      OUKITEL already finished Android 7.0 nougat for the big battery smartphone K6000 Pro. Since it is cross-OS updating and there may appear many bugs which can’t be fixed through software updating, for the moment, OUKITEL don’t release FOTA for the Android 7.0 OS.
      Though the software can not be updated to Android 7 through OTA, it can be flashed by computer.
        Please backup all your data first, then download the following files to your computer. there are process to indicate you how to flash the software on the tool.
        Android 7.0 Software(OUKITEL_K6000_Pro_FZ_V21_20170513):
        software: https://mega.nz/#!ktgygBSR!CW0kQRcWf...T1eY536abMa5tk
        Install tool: https://mega.nz/#!rMVGFLzB!5LtavmoUa...plAKu7TMmON7F4
        Process: https://mega.nz/#!4oJCBBzY!M1EgXJGyM...ihzfTjxDmjjDjM
        OUKITEL K6000 Pro will have a new version for android 6.0,we will test on the new version about updating to android 7 through FOTA. It takes some time to do this. For the moment, the only way to update to android 7 for K6000 Pro is to flash on computer.
          Found this information on your site.. my bad..
            software file does not exist...
            do you have other link for download?
