S905x fw
Sorry about that! Should've included a link.
Originally posted by blinkone View Post
There you go,Uninstall v2.0.7.2 first then install v2.0.8
USB_Burning_Tool_v2.0.8_x86.rar
https://mega.nz/#!U4UTBbjI!lMc7Co-dz...RWYRYtK7-wg0nk
That's an UPDATE file ... you don't use the USB Burning Tool for Updates (only Full Rom Flashing AFAIK ... well, that's i've done .. worked fine everytime)
i don't know what version they are up to now .. but rv_101 is old
rv_102 here: http://freaktab.com/forum/tv-player-...-10-100-lan-bt
Extract, place on SD Card, then on your Android Box in Settings ... update/backup select update.zip
edit: quick google search .. latest update is rv_104 (can't find a link though, sorry)
All s905x are not same HW . There are differences in kernel and bootloader.
I flashed to my X96 box wrong firmware with SD card update.
After that I could not flash either SD card or USB burning tool.
Finally solved problem with Terminal Emulator by writing for correct HW boot , bootloader, dtd and recovery images.
After it I could use Usb burning tool to update correct firmware.
Learned, that don't update firmware of other HW to your box, if don't want troubles.
Hi, thank you for your help.
as the way it is i cant do nothing with the box.
Can i boot to it from sd card and install the full rom from the sd card?
my box is m8s iiLast edited by andremariz; 05 November 2016, 03:09.
Originally posted by hikka View PostAll s905x are not same HW . There are differences in kernel and bootloader.
Mine is not working, cant flash via sdcard or usbbrurning tool.
What do I need to flash via terminal emulator?
Originally posted by windziu View Post
Could You tell me how did u flashed via Terminal Emulator? Yours box was running?
I could not use either USB burning tool or SDcard, before wrote correct Bootloader.img, Dtd.img , Boot,img and Recovery.img.
After that could use USB burning tool.
I think you might also have lost your bootloader and dtd. Need to get somehow correct bootloader in .
There are currently 3761 users online. 0 members and 3761 guests.
