Need firmware and help to flash T8-AML-V3 back to android 5.1
    Hi
    Im a newbie looking for helping in A. Locating the correct compatible firmware for my T8-AML-V3 box and B. Help in flashing NOT bricking it
    Im in the uk with an Entertainment box brnded T8-aml-v3 box. Im wanting to wipe the Entertainment box firmware and replace with standard android 5.1 firmware and launcher as im used to using android menus that are standard launcher images not plastered with a companies logo everywhere.
    Now i see the t8-aml-v3 is an amlogic S812 and poss similar to a zoomtak t8.
    Can you help as its the first time doing this and dont want to brick it as it was a gift for me during my chemo. Also any reboot zip files to help fix if bricking occurs wld be great.
    Have added box.spec below:
    • Model: EntertainmentBox E Box T8-AML-V3.
    • Processor: Amlogic S812 Quad Core Cortex A9r4 2GHz.
    • Operating System: Android 4.4.2 KitKat Rapid.
    • GPU: Mali-450 Octa Core @600MHz.
    • Power Indicator (LED: Power On: Blue – Standby: Red.
    • RAM: 2GB DDR3.
    • Internal Memory: 16GB.
    • Expandable Memory: SD Storage (up to 32GB).
    • Google Play Store: Yes.
    • Kodi 15.2 Helix pre-installed: Yes (Reliant and most stable).
    • HDMI: Yes.
    • USB Ports: 3 x High Speed.
    • 10/100 Ethernet: Yes.
    • Flash Support: Yes.
    • HD Video Playback: Yes, Supports 1080p Full HD Videos.
    • 4K Video Playback: Yes, Supports 4K Ultra HD Videos.
    • 3D Video Playback: Yes, Supports 3D Hardware Graphics Acceleration.
    • Video Support: H.265/H.264/H.263/VC1/WMV/MOV/MKV/AVI/RM/RMVB/FLV/MPEG-1/MPEG-2/MPEG-4.
    • Music Support: MP3/WMA/APE/FLAC/AAC/AC3/WAV.
    • Photo Support: JPEG/BMP/GIF/PNG.
    • Card Reader: SD/SDHC/MMC cards.
    • HDD File System: FAT16/FAT32/NTFS.
    • Network Function: Miracast, Kodi, SPMC, Airplay, Skype, Picasa, YouTube, ect.
    • Gaming: Supports 3D gaming.
    • I/O Ports: 10/100 Ethernet, HDMI, Micro SD, 3.5mm Headphone Socket, Optical Audio out, Power Port.
    • WIFI: Wireless LAN 802.11b/g/n – 2.4/5GHz Dual Band.
    • Power: DC 5v/2A.
    • Accessories: HMDI Cable, A/V Cable,Power Adapter, Remote Control, Manual.
    • Colour: Black.
    Can anybody help with this? I would like to do the same
