Sunvell T95P TV Box 2/8GB WiFi
We lower the price! Same coupon, lower price!
coupon: GBT95P
Price: $39.99
http://www.gearbest.com/tv-box-mini-...47.html?wid=21
#1 Gearbest TV Box & Mini PC Page
#2 Flash Deals Flash Deals
#3Coupons Coupons, Coupons and More Coupons
What we have today is something small to have a bit of a look at
Thanks to Gearbest and DHL for fast Delivery
Sunvell T95P 2/8GB 2.4ghz wifi 1 x usb port 1 x HDMI port and a TF card Slot all built in to one small package
This will be no Power House, but I feel it will do the job on most thing it is asked.
Temps are a little warm to be expected such a small all in one Package.
Whats Is the Box
Not a lot of room in this little unit
There is a Thermal Pad and it sits a top a piece of Metal above Power Supply Unit so there is some thermal dissipation happening.
Underside Side PCB closest to Power Pack of Plug
Topside PCB, IR pick up no obstruction point to top of box easy.
Its has power Indictaion Blue On Red Off
WiFi Chip
eMMC
Look at O/S and UI standard Sunvell.
CPU: http://browser.geekbench.com/v4/cpu/1216946
Compute: http://browser.geekbench.com/v4/compute/275628
Performance ok for this type of unit
Found WiFi good at this location, streamed Netflix easy,
Easy Setup up Google Play store and accounts etc, updated apps pretty easy.
Kodi 16.1 with Tv Addons so bloated a little., FTMC will go on soon, Unit running ok for a 2/8
Remote works rather well I was about 3 mrts away pointing in all directions and it seems to the job well.
Small and Simple, going away on holidays, or caravan would have its uses for sure.
You could also remanufacture the complete unit in any form you wish really due to its compact size easily could fit into some really tight places.
Mount in a small TV of Projector LCD Panel feed it with volts, great little project.
Gearbest
Coupon: GBT95P
10 Bucks off or there abouts may still be activeLast edited by trebor; 02 December 2016, 06:59.
There are currently 2905 users online. 1 members and 2904 guests.
