Zattoo on mk908??
    Zattoo on mk908??
    Hi, I installed tha app Zattoo to watch tv Channels through VPN on my tronsmart908. Differently from other android devices (smartphones), the vision is a bit slowered and at an ugly resolution (it seems a 72x72 ..!!). I have 4.2.2 and fins on 1.5 installed. Does anyone can use such app correctly and watch at a decent resolution?? Which is the problem in your opinion? HDMI restrictions (but using the app with a PC hdmi it works) ..it shouldn't use any flash player, and on my Samsung smartphone ace 2 it works perfectly....
    note I can watch decently other channels like BBC with iplayer..
    thanks!
    Fra
    thanks!
    Fra
    Hi, i have the same problem. Do you have a solution?
    alan1
      thanks!
      Fra
      I have Zattoo working on Mini NEO X7 (006c firmware only!), but only via WiFi internet access. In fact Zattoo Android app does not have a bitrate setting for wired Ethernet and always sets it low. So make sure that you use Zattoo with WiFi and have related bitrate set to high.
