How to check if a device is defective?
Hello, I have a beelink r68 TVbox (AP 6335). My device crashes a lot (reboots without notice) and also the apps are crashing (i get a message "google services stopped'). I tried to flash some different firmwares ( i tried to reset the device first offcourse) but nuthing helps. How can i know if my device is defective? Thank u in advance.Tags: None
Originally posted by mitchell4you View PostWell.. few thoughts
First try... a different poweradaptor
Second try emtying the Cache (settings/storage/cache)
Install android tuner... Check kernel logs... Check temperature... (does it reboot under stress? ) perhaps do a one click tuning
Cheers
First, I changed the adapter and it still remain crashy...
Second, emptying the Cache did not help either.
What about the rest (Install android tuner... Check kernel logs... Check temperature... (does it reboot under stress? ) perhaps do a one click tuning)?
I there a guide or something? I really apriciate your willness to help.
There are currently 2600 users online. 1 members and 2599 guests.
