remote app
    remote app
    I have had the T428 for about a month now. It works pretty well for the most part. Still can't play hulu, but that's being worked on by our wonderful friends here. The question I have is does anyone have a favorite remote or remote app? I have thought about buying a mini keyboard, but I also think droidmote works pretty well.
    I think it would be great to have a remote app that was like vnc or remote desktop that just displayed the actual screen on the phone/tablet you were using and you could use your finger/stylus to select items on the screen with more accuracy. Anyone know of anything like this.
    Thanks for your comments and opinions.
    Typhoon
    I suggest DroidMote. With DroidMote you can do all with your mini pc.
    I use it from one year and i'm very very happy.
    Is simple, faster and complete.
    You can play all games also with your hardware controller if you attach this to your phone via bluetooth, or wireless dongle or with usb otg cable.
    For games that support external controllers you can play directly and for touch games you can create touch profile in very simple way.
    DroidMote is the only one with two year of experience and tested from thousand of users. All other apps are only crap clones.
    DroidMote is one of the best tool for an android hdmi stick.
    And you can control in the same way also Windows and Linux.
      Give this a shot if you want remote display.. otherwise.. I use droidmote mainly for remote purposes
      Android VNC server - https://play.google.com/store/apps/d...org.onaips.vnc
      Question Reality: Find Your Own Truth!
      My MK908 Cooling Mod and Breakdown : HERE
      My RK3188 Github Repos (NOTE: Works-in-Progress!) : HERE
      Sent my Epic4G AND Backflip into nearspace... what have YOU done with your phone?
      Want to say thanks for something I did/said or DONATE to my drink fund?
        droidmote works really well in every situation
        must have app!
          I agree completely, but OP was looking for something with possible remote display on their device and droidmote doesn't do that
