Hardware Specifications | ||||||||
Chipset | Amlogic S905 Quad Core 64bit Cortex-A53 up to 2.0GHz | |||||||
GPU | Penta-Core Mali-450 upto 750MHz+ | |||||||
OS | Android 5.1 | |||||||
Flash | 8GB NAND FLASH | |||||||
Ram | 1GB DDR3 |
MXQ Pro 4K s905 upgrade firmware to marshmallow
Is it possible to upgrade my box to Marshmallow firmware? it is currently running 5.1.1I've installed Kodi 17 beta 5 and is running fine, I just wish I could upgrade the firmware too? any guidance is welcome as I cannot find the right firmware.Tags: None
Originally posted by Television View PostIs it possible to upgrade my box to Marshmallow firmware? it is currently running 5.1.1I've installed Kodi 17 beta 5 and is running fine, I just wish I could upgrade the firmware too? any guidance is welcome as I cannot find the right firmware.Hardware Specifications Chipset Amlogic S905 Quad Core 64bit Cortex-A53 up to 2.0GHz GPU Penta-Core Mali-450 upto 750MHz+ OS Android 5.1 Flash 8GB NAND FLASH Ram 1GB DDR3
You also have an unknown S905, the manufacturer probably already abandoned this box and moved on to the next one, so will also not release MM in the future.
Originally posted by mitchell4you View Post
[UPDATE]: As it turned out, I had a defective micro SD card. So, after replacing the micro SD card with a good one, my MXQ Pro is running very smooth with LibreELEC OS.Last edited by Habibie; 23 March 2017, 18:10.
Here you can get a custom firmware for the MXQ Pro 4k. It is still android 5.1.1, but it uses already the Google android TV leanback launcher (ATV).Custom ROM for the MXQ PRO 4k - p201 stable . fast . clean . leanback ATV . custom rom This custom rom mod is based on the UGOOS AM3 V0.0.7 TV firmware ...My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
No, only S905X runs Marshmallow.
MXQ Plus TV Box Amlogic S905 Android 6.0 Firmware Pack
and
Android 6.0.1 Firmware V1.1.1 for Ugoos AM2 440.33MiB 21/06/2017 MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
Hopefully at some point someone is able to port the 6.0 S905 codebase from these to other boxes, especially the numerous P201 variants.
Television, if you're able to open your box and look at the circuit board for model number designation markings, and the wireless chipset model number, that may help you find a newer compatible ROM to flash without problems.
Originally posted by PaulieP View Post
There are now two different 6.0 Marshmallow releases at least I've seen for the S905:
and
https://mega.nz/#!itlVxDqQ!2WimYF0eR...e0XsZ-CbuK0rj0Android 6.0.1 Firmware V1.1.1 for Ugoos AM2 440.33MiB 21/06/2017
Originally posted by Habibie View PostThank you. But, when I downloaded the firmware from both the above links, they are the same files (AM2_1.1.1.7z).
The second is the AM2 1.1.1. IMG.
Hi I just tried them. They are not the same files, I would retry the first link. the file from MEGA is 1652503 MXQ Plus TV Box Amlogic S905 ROM Android 6.0.zip, flashable zip
I just noticed these are for an MXQ Plus and not MXQ Pro. CUrrently, my MXQ Pro is running on a LibreELEC v8.1.4 off a USB memory stick. I wonder if it is possible run this firmware through a USB memory stick, too, to see if it will work.
Thank you and you are right. I just re-downloaded the 1st and it is a different one.
So the only reliable way to find compatible ROMS is to actually look at PCB markings.
Dont know if they will work for you but the 6.0 roms are at least a starting point for those who said there is no 6.0 source for S905 amlogic boxes..
I think the main problem is also that a lot of companies use different boards within the MXQ Pro generic shell. There are probably 10 different boards that have been used all called MXQ Pro with the same external logo and processors from RK3229, S905, and S905X. Same for MXQ, MXQ 4K, etc etc.
https://mega.nz/#!NU1BwbrQ!avFaeKUPu...PDMLIuGyLrcmro
andhttps://mega.nz/#!itlVxDqQ!2WimYF0eR...e0XsZ-CbuK0rj0Android 6.0.1 Firmware V1.1.1 for Ugoos AM2 440.33MiB 21/06/2017
http://freaktab.com/forum/tv-player-...r-s905-devices
I have been attempting to port this to a box with very similar hardware and managed to get wifi working but I dont have Ethernet because the Ugoos AM2 does not have a LAN port.
Originally posted by satanuke View Post
Check this thread
Did you try the first link also? It's marshmallow but for a different S905 box
There are currently 2517 users online. 1 members and 2516 guests.
