Tv Stick / Box capable of screen rotation
    Hi there, does any of you know of an android stick / tv box, that has the ability of rotating the screen 90 degrees. We have tried several sticks with 3rd party rotating apps, but none have worked so far.
    We have an in-house statistics app that we would like to run as wallboards on a rotated widescreen i portrait mode -, but so far no luck. It sees that no of the original roms support it.
    The requirements are:
    - must be able to rotate screen
    - must run at least android 5.11
    If you know of a either a stock rom stick - or a stick/rom combination that will allow this, I would appreciate it.
    Hello and Welcome to Freaktab !
    Any S905 or S905x Device supports Rotation.
    S905 runs Android 5.1 and S905x runs Android 6.
    Good choice would be a Tanix TX3 Pro.
    Regards
    Ray Trunk
      Hi Ray, thanks a lot for the swift reply. I have just ordered two Tanix TX3 Pro. Looking forward to see how they perform.
      Btw. Thanks for a really friendly forum
        Your welcome !
        I can say you the Tanix TX3 Pro is a really good Device.
        Perform very well. A Client of me use it for Digital Signage.
        Good Wifi and Stable.
        If you need more Help let me know.
        Neomode
