PIPO M7Pro touch screen problem
    Hi everyone,
    I changed the touch screen in my Pipo M7 and now the display seems turned, I'm not able to use the tablet without an externall mouse, someone knows how to edit the build.prop for trying to fix it? I taked a look to this post http://freaktab.com/forum/tablet-sup...amp;viewfull=1, but it is different from mine and maybe for M7 there are more options.
    Thank you
    Hi elbraga ,
    most Pipo M...Pro Users how has changed their Display have this Problems ,this has something todo with the kernel.Look for more Info in M7 & M9Pro Threads.
    The Pipo's now are a little bit old and not many Support anymore.Try to contact D33 with PM ,he was is the Expert for this.
    good luck
    gefattern
      Thanks, I will continue researching
