Mk809ll stock 4.2.2 firmware
    Hi all im looking for the mk809ll rk30mtk stock firmware i can't find it any where
    My Works @XDA:
    AVD Rom Xperia J The Way Stock Should Be
    Pre Root Xperia J 4.12
    Deodex Xperia L
    Deodex Xperia Z kitkat
    Stock Xperia Icon's For CM11
    I could not find the firmware for MK809II too. I have installed finless bob 1.7 UG802 firmware but my device does not work properly with this firmware. Did you find the suitable firmware for MK809 II ?
      ...and why do you not try this ROM?
      JDfense
        Originally posted by JDfense View Post
        Its not 4.2.2 I had the stock 4.2 when i bought it but i tried flashing an Xperia Walkman mod and forgot to backup and video streaming wrecked on it so now i only have 4.1.1 and bluetooth won't work and can't seem to fix it.
        My Works @XDA:
        Deodex Xperia L
          I have a Justop K9B which is actually an MK809II. Try this firmware:
            http://www.justop.com/forums/showthread.php?tid=2278
            This would not flash error at IDB point in flashing process.
            My Works @XDA:
            Deodex Xperia L
              MK809 II 4.2.2 ROM
              For my MK809 II the best solution is ROM 4.2.2 for MK812. It's R-BOX Rom, WiFi and Bluetooth work perfect -of course Mediatek based WiFi and Bluetooth chipset.
              Try MK812-Firmware-V4-2-2-NoExt-Antenna.img - https://www.dropbox.com/sh/sqd2f2l8z...3D0swn&lang=en
              JUSTOP_K9B_FW_JB42_V2.0_root_31052013 and MK812-Firmware-V4-2-2-NoExt-Antenna seem to be exactly the same.
              I flashed on my MK809 II everything that I came and my conclusion is as follows:
              1. Finless 1.7a - nice ROM, but but there is a problem with reboot app, the problem arises when you want to get into Picuntu, mini pc hangt and you can not get into the android, bug in reboot app
              2. imito_mx1_2_finless_20_jb422 - just fine ROM, small problems with browsing, sometimes browser blocks
              3. kasty-imito_mx1_mx2-422-20130504-rooted3 - the same story with browser
              4. original imito 4.2.2, update.img - the same story with browser.
              These are my experiences and and I hope I helped a little.
                thanks alot great rom
                  Could anyone whos flashed the MK812-Firmware-V4-2-2-NoExt-Antenna.img Rom confirm whether it
                  - has a 1080p kernel
                  - has root
                  - does the RK remote work with any 4.22 roms ?
                  cheers
                  cod
                    interesting in antenna
                    Hello everybody,
                    I'm new here and i've a question for you.
                    What type is in your's device (MK809 II or MK 809 I ) antenna's type iron or plastic.
                    Cos i have big issues with connection (router).
                    Maby this problem is soft?
                    My device is http://goo.gl/J9HEEg and I think this is MK809 II.
                    But I've and (I think) MK809 I.
                    Thank you.
                      I have tried alot of roms for this device I agree that the mk812 v4 is very good but I have sound issues the sound works fine but there is a very loud disturbance with this rom has any one else had this problem?, I have three of them and its the same issue every time, It maybe my Hannspree TV.. any help will be good thank you
                        cozyswan mk809ii best rom
                        hello all
                        recently got the mk809ii from cozyswan on amazon. have 4.2.2 stock rom installed and i have had some stuttering in xbmc. What is the current best rom for me to use, the mk812 v4? does wifi and BT work in it?
                          Originally posted by Jimandroidpc View Post
                          hello all
                          Tried to install tons of ROMS over the weekend, came to a few conclusions.
                          MK809II by Cozyswan has the Mediatek Wifi / BT, and multiple other iterations.
                          -Most of the ROMS I tried had faulty Wifi and BT.
                          -It seems this version needs its own Wifi & BT Driver.
                          I Have found the Stock 4.1.1 firmware that has well functioning wifi, but no BT @ http://pan.baidu.com/share/link?shar...&uk=3509931586 (click on white box w/ down arrow, then white box again)
                          This ROM seems stable and runs XBMC pretty well. Still would like to get BT working...
                          My Specs:
                          cozyswan mk908ii opened up
                          green pcb rk3066 dongle mk809ii rev 1.1
                          20130413 (i think)
                          rockchip rk3066
                          4 elixir modules/chips
                          some chip maybe wifi- t659102
                          chip 1 --
                          mediatek - mt6622n
                          1242-bgjl
                          btgcb465
                          chip 2 --
                          mediatek -mt5931sa
                          124_ _bmah
                          btpmr258
ID:	431860Click image for larger version
ID:	431861Click image for larger version
ID:	431862Click image for larger version
                            My Specs:
                            20130413 (i think)
                            rockchip rk3066
                            can you give another link?
                              Try this mate,Android 4.2.2 MTK for 809II
                              There is a KitKat version as well, I have tested it ,all fine.
                              www.hindotech.com
                              contact: 0086-755-89344684
                              email: [email protected]
                              Skype: luke.guo1
