Alfawise 912 Review
    Alfawise 912 Review
    I had the device for a bit now and heres my short tear down and review.
    First try was to install beelink software both these boxes are almost the same. With few difference like heat sink ect. The remotes are the same as well and everything worked on beelink including updates.
    I did notice some boards not set right in box that left a gap at heat sink to cpu tape. Once set right they worked with no issue.
    Opening the box needs thin métal to pry carefully at sides of bottom of the box.
    Alf software os. Everything runs well box shows no heating issues even when under heavy load. Wifi hooks up fast and connects every time. Network same.
    bluetooth file transfers standard.
    I was actually shocked that heat wasnt an issue because no vents into the unit. (We all know how they cost so maybe thats why device was on sale &#128512 must be the
    Antutu Scores 40000 plus
    games run well
    Video everything i threw at it work with little issues.
    Kodi. Some video codex issues in 16. 17 works with very little issues more to the build then device. Disable media surface and media in advance setting stop reboots but thats a kodi issue not the box. Amilogic i understand knows this as well.
    Playstore - No issues everything works and loads
    All in I say stable device that does as it says for the price good job.
    Case is the exact same as the tanix 905x so if youve taken that one apart you will be able to get the case apart easier as we know some have had issues getting this one apart. (Not mentioning any by name 😝&#128514
    Ill post photos and screen shots shortly.
ID:	609606 Running Beelink rom on Alfwise Click image for larger version
ID:	609607 Click image for larger version
ID:	609608 Click image for larger version
ID:	609609 Click image for larger version
ID:	609610 Click image for larger version
ID:	609611 Click image for larger version
ID:	609612 Click image for larger version
ID:	609613 Click image for larger version
ID:	609614 Click image for larger version
      Originally posted by scooter2014 View Post
      [ATTACH=CONFIG]n609606[/ATTACH] Running Beelink rom on Alfwise [ATTACH=CONFIG]n609607[/ATTACH] [ATTACH=CONFIG]n609608[/ATTACH] [ATTACH=CONFIG]n609609[/ATTACH] [ATTACH=CONFIG]n609610[/ATTACH] [ATTACH=CONFIG]n609611[/ATTACH] [ATTACH=CONFIG]n609612[/ATTACH] [ATTACH=CONFIG]n609613[/ATTACH] [ATTACH=CONFIG]n609614[/ATTACH] [ATTACH=CONFIG]n609615[/ATTACH]
      What is the score if you run its stock firmware ?
        The firmware is pretty much identical except for kodi addons. Same scores.
