VORKE Z1 Amlogic S912 Android 6.0 3G DDR4/32G eMMC 802.11AC WIFI Gigabit LAN Dolby BT OTA
    VORKE Z1 Amlogic S912 KODI 17.0 4K VP9 60FPS HDR Smart TV BOX Android 6.0 3G DDR4/32G eMMC 802.11AC WIFI Gigabit LAN Dolby HDMI CEC DLNA Bluetooth OTA
    Brand: VORKE
    Model: Z1
    Type: TV Box
    Hardware Operating System: Android 6.0
    CPU: Amlogic S912 Octa core ARM Cortex-A53
    GPU: ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
    RAM: 3GB DDR4
    ROM: 32GB eMMC
    Extended Storage: TF CARD Support 1~32GB
    Communication Wifi Connectivity: Built in 2.4G/5G Support IEEE 802.11 b/g/n/ac
    Ethernet: 10/100M/1000M RGMII
    Bluetooth: 4.0
    Media Video Supported Video Output:
    Built-in HDMI 2.0a transmitter including both controller and PHY with HDR, CEC and HDCP 2,2, 4Kx2K@60 max
    resolution output
    Video Codecs:
    VP9-10 Profile-2 up to 4Kx2K@60fps
    H.265 HEVC [email protected] up to 4Kx2K@60fps
    H.264 AVC [email protected] up to 4Kx2K@30fps
    H.264 MVC up to 1080P @60fps
    MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
    WMV/VC-1 SP/MP/AP up to 1080P@60fps
    AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
    MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
    MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
    RealVideo 8/9/10 up to 1080P@60fps
    WebM up to VGA
    Multiple language and multiple format sub-title video support
    MJPEG and JPEG unlimited pixel resolution decoding (ISO/IEC-10918)
    Supports JPEG thumbnail, scaling, rotation and transition effects
    Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file
    Audio Supported:
    Audio Container:supports MP3 / AAC / WMA / RM / FLAC / OGG and programmable with 5.1 down-mixing
    Audio Ou:HDMI/SPDIF Data Output
    Picture Supported: HD JPEG/BMP/GIF/PNG/TIFF
    Resolution: 4K2K@60FPS
    KODI: KODI 17.0
    Interface 1* HDMI 2.0 output with CEC 2.0 4K*2K @ 60Hz
    2* High speed USB 2.0,support U DISK and USB HDD
    1* TF CARD Support 1~32GB
    1* 3.5 Phone out CVBS&L/R output
    1* SPDIF output
    1* RJ45 LAN Ethernet 10M/100M/1000M
    Other Features Support DLNA, Google TV Remote, LAN, 3D Moive, Email, Office suit etc
    Power 5V/2A Power ON :blue; Standby :Red
    Dimensions&Weight 130*109*24mm
    214g
    Package Contents 1 x TV box
    1 x IR remote
    1 x HDMI cable
    1 x Power adapter (A right AC Adapter will be s
    Geekbuying
    Gee this doesnt look slightly familiar in the slightest.
    Ok I'll take that back... IF this thing really has 3GB of RAM, instead of the normal 2GB.
    But, this is still clearly a Videostrong Box, just like the Mecool, and the YokaTV, and the T9X (IIRC)
      Hmm....DDR 4 memory? Any benchmarks?
        VORKE Z1 Amlogic S912 4K VP9 60FPS HDR Smart TV BOX Android 6.0 3G DDR4/32G eMMC 802.11AC WIFI Gigabit LAN Dolby HDMI CEC DLNA Bluetooth OTA
        Lets have a bit of look at the Vorke Z1 thanks to Geekbuying and DHL super fast.
        I have left the protective easy peal cover on the top. Has a Hi Gloss Finish, just left covered for protection
          Lets now have a look see at what makes this thing tick
          Top View Lid off
          Ram
            Final Part a Information and Benchmarks
            Current Firmware Versio
            Full Detail > http://browser.geekbench.com/v4/cpu/1347715
            FUll Details > http://browser.geekbench.com/v4/compute/310028
            Good Scores on this test, best I have seen for awhile
            Good Benchmarks scores here as well
            Good also for a standard rom
            Slight Blue/Purple Glow when on.
            Slight Red Glow when Off
            After day of using the Vorke Z1, fairly impressed with overall speed and how will this unit is running Smooth, all as expected with 3/32gb, Nice rom for a first run and no major issues, WiFi and Ethernet speeds good at this location Great to see, Netflix same as usual very watchable, Plex same as usual
            Temps only to Mid 60's on Ethernet close to 70's on Wifi when Pushed idle at present 40c, very good.
            Nice rom should do the job easily for most.
            Thanks to Geekbuying
              I just installed and tested TWRP recovery for Vorke Z1.
              this is recovery for Netbox a95x and S905x from russian forum 4pda.ru.
              First I start this recovery from USB pen drive and mad backup, then restored without any problems.
              After this I used rashr tool and flash recovery. Now I can do backups and restore them without presing recovery key - just
              reboot my Vorke Z1 into recovery.
                New superceleron Custom Rom for the Vorke Z1 within 24 hours another Oh So Excellent Rom
                  Just picked up this box on Amazon prime $99(easy returns). The stats are very good. Where's the link for new custom ROM?
                  Sent from Nowhere
                    Sent from Nowhere
                    You have to wait, later today (im in portugal...)
                      As mentioned and stilll 4 or more hours to go
                      One sweet rom this is
