I install firmware from ugoos UT4 device to my Z4 and i have a problem with power button.
I have to always press and hold to working, if not device is going off.
Temporary i found solution : i connect otg cable to any usb port (in another device)and then Z4 works perfectly (HD Audio etc...).
Do you have some solution for power button or can you make some patch?
