Egreat A5 Hi3798CV200 4K HDR 2G/8 GB Upgrade Instructions
    1. Download the latest firmware, file name should be xxx.zip, then copy them into fat32 format 2.0 USB stick root folder, it should be the same as below;
    2. Unplug the power adapter, then Plug USB stick into this 2.0 USB port as the picture showed;
    3. Press the RESET button with Toothpick or similar, and at the same time plug the power adapter
    4. When Android robot starts processing on the screen, then release RST
    4. Please wait will take about 5 or more minutes to complete, and don’t power off.
    * A5 player will reboot after new firmware installation completely.
