FIrmware: Sunvell T95U
Updated. From version T5UPO002 to T5UPO005
With the old version when the bottom bar was closed there wasn´t any way to see it again until reboot. With this version the problem persists. At least I have not seen the flash green problem and the image is not dark like other TV Boxes. There is an option to activate the HDMI-CEC. I don´t remember if it was with the old version. I can´t test because my TV is not fully compatible.
@trebor,
Thanks you very much for that, not to be ungrateful but any chance that we might see v06 as a download soon? (or higher)
Can this "kit" also be used with "USB_Burning_Tool", and would that be like a clean factory installed box with no settings/data retained?
Originally posted by Teddybee View PostI have got my T95U pro, it has an fw version T5UP0006
T95 and Pro version uses the same fw?
When you run "BACKUP&UPDATE" do you get a OTA error?
-tv99
There are currently 2388 users online. 0 members and 2388 guests.
