Best ROM for Z4
    Best ROM for Z4
    Can someone suggest most stable ROM for Z4 which have all ports / HD audio / smooth 4K / Audio passthorugh working. Also it it is Marshmallow ROM that would be great.
    Welcome,
    After months of searching and traying I finally found solution for DD and DTS in "Kodi" by HDMI Bitrate and DTS HD-Master and Dolby True HD in MXPlayer
    Solution:
    1. You have to install "Z4_UGOOS_MOD_V1.5" firmware made by @Yablar.
    2. Change in audio settings to HDMI Bitrate.
    3. Delete default Kodi version.
    4. Install "ugoos_kodi_20160620.apk" from ugoos oficial page.
    5. In ugoos kodi SYSTEM settings (expert) choose transfer to output device on (or something similar) and all settings DD,DTS... to on. Don't turn on DSP.
    6. In Video settings you have to turn off "Accelerate RKCodec" in "RKMC" tab because if is ON the video is not playing fluently.
    Thats all. Have a nice day/night
      This is my post from xda
      For me today the best solution is combination: Z4_UGOOS_MOD_V1.5" firmware made by @Yablar and the newest firmware Ugoos UT4 1.1.4.
      How to flash i describe in different topic on this EKB3368 page.
      You can choose ugoos 1.1.4 or ugoos 1.1.4 for Android TV (it looks like Nvidia shield TV software).
      In this solution you have ugoos kodi version 16 from November 2016 and hd audio works superb.
        Originally posted by lord_yabol View Post
        Thanks lord_yabol could you provide me links to try out ugoos 1.1.4 for Android TV on my Z4. Appriciated your help. And Agreed Z4_UGOOS_MOD_V1.5 is the one best ROM so far.
          This are links from official ugoos page.
          1.1.4
          1.1.4 TV (Android TV) if you like:
          How to flash:
          First you have to be sure that you have installed "Z4_UGOOS_MOD_V1.5" firmware on the box because in next step you flash only system.img from ugoos 1.1.4 software..
          1. If it's the first time, you need to install drivers or manuals DriverAssitant connected devices
          2. Run AndroidTool.exe
          3. Switch "function advandced" tab, select the image "ut4_1.1.4.img" Press "Unpack"
          4.Copy UT4_1.1.4\AndroidTool\Output\Android\Image\system. img copies to UT4_1.1.4\AndroidTool\Image
          5. Switch to "Download image" tab unsect all tabs except the "system"
          6. Connecting to the computer through the USB OTG port equipment (full guide you can find printed by connecting "ugoos_firmware_upgrade_guide")
          7. Click on the "RUN"
          8. Once the update is complete restart to mode TWRP recovey select wipe.
            it works and so far looks solid. Specially Kodi is good.
              one can not have a stock firmware updated and ready for use without having to make changes after the installation?
              I see that almost all of the firmware they need to make changes after the installation, and unfortunately not everyone is able to make them!
              I speak of stock firmware, and not of ugoos mod rom!
              I have a z4 2g / 16g EKB368
                Great roms thanks. Had a problem before but it just was drivers
                  Hi I've try to overvrite system with new UGO 1.1.4 octacore but WiFi does not be detected!
                  By the way .. how to do point 8? I've just reste factory from Settings.
                  1.1.4
                  How to flash:
                    Always read and confirm model before flashing. Number of posts regards Z4L having different WiFi chip.
                    BTW the above combo given by @lord_yabol is excellent. Thanks.
                      Screenshot for multiwindow view from above firmware. Smooth and stable Click image for larger version
                        If you like the pro & cons of the google android leanback TV launcher, this custom rom should make definitely the race
                        ROM (Image/Firmware) for the Z4 RK3368 android TV Box (Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6) stable . superfast . clean . leanback . android TV (ATV)
                        My contributions to the community
                        [ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
                        [ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
                          1.1.4
                          How to flash:
                          works, but i can't install any apk... says "insufficient storage space" but 12gb are free
                            Then just use the original Ugoos firmware posted on their blog with ethernet, that doesn't contain this bug.
                            Did you clear data or wipe from TWRP recovery or did a factory reset?
                              yes, i did. I can't use the original Ugoos firmware, cause my android box is a Z4 Rk3368. The funny thing is In ugoos 1.1.3 this error doesn't happen. Any solution? (I need the ugoos 1.1.4 because has fix for netflix sound).
                              Thanks in advance
