When the device restarts, it loads all of the way except that there is nothing on the home screen except for the wifi signal and the power button. The home screen is non responsive as nothing is loaded. I cannot pull down the settings or anything. I am able to uninstall it by running the corresponding uninstall file and it goes right back to normal.
When this device was stock, I was able to load the xposed framework so I know it's not that the files don't work with this processor/box combo. Would it be the ROM?
If anyone is running the same setup, are you able to run the xposed framework? If so, could you let me know if I need a custom zip file and maybe I could be pointed in the right direction for a download. I have been looking but the keywords lead me to way too many unrelated search indexes.
I'd really appreciate some feedback, Thanks..........
.gif)
